Glacier: questions re: battery
Old 1st Jan 2007, 11:37 am
Que Que is offline
Probably original nokia, all low cap? The ones I bought are Maxcell Lithium Polymer, maybe the Lithium Ion's are lower capacity? Someone posted here he fit a bl-5c, but with altering the case to make it fit.
Old 2nd Jan 2007, 12:12 am
Default Re: Glacier: questions re: battery
Hi, What type of player are you refering too, for these batteries to fit into??
Just curious??
what are the physical size dimensions of these particular batteries
Cheers
Joff
Old 2nd Jan 2007, 6:13 am
Que Que is offline
Joffa, the topictitle says "Glacier", a google for the bl-4c dimensions gives 53.10x33.40x4.50 mm. You posted before you had your morning coffee, right? (just kiddin')
Old 2nd Jan 2007, 8:06 am
I also want to find a good source for an extra Nokia battery for my Glacier. The 2 sources from the Netherlands selling 1700mAh batteries do not sell worldwide! I Googled it and could not find anyone online selling 1700mAh versions of this battery. Which leaves the 900mAh versions. Now I was told here in these forums that the Glacier can fit a BL-4C or a BL-5C. Now I read "not the BL-5C without modifications to the player".
Can anyone give me a clue as to what my best options are, for getting a spare Glacier battery? (Don't want to have to modify anything)
Old 2nd Jan 2007, 8:15 am
Que Que is offline
[web:f7d5e985fc]http://cgi.ebay.nl/Nokia-6100-6230-6210i-6600-6630-Akku-Li-Polymer-1700mAh_W0QQitemZ230037164278QQihZ013QQcategoryZ30 416QQrdZ1QQssPageNameZWD1VQQcmdZViewItem[/web:f7d5e985fc]
It does say Verenigde Staten (United States) in the posting tariff section, €4,10 without or €8,70 with insurance. It is a German shop selling Maxcell batteries.
Just a few Questions about Glacier from UXcell mark04912 General Discussion - Uxcell.com 5 8th Jul 2007 7:50 pm
Glacier battery life with Nokia BL-4C timoggy General Discussion - Uxcell.com 7 21st Feb 2007 2:44 pm
a couple of glacier questions? manutd6899 General Discussion - Uxcell.com 4 2nd Feb 2007 5:36 pm
Glacier-not-so-great and palladium questions honza General Discussion - Uxcell.com 2 14th Jan 2007 2:55 am
Questions about Battery Jens General Discussion 1 26th Sep 2006 11:02 am
