Player return to Uxcell
Old 20th Jan 2007, 12:51 am
Default Player return to Uxcell
HI, Before I email them, i was just wondering about the policy for sending back my dodgy unit!!
I have had my player about 4 weeks, and apart from the initial issues like battery and dodgy firmware, all was ok :roll:
My unit now is not connecting to PC or wall outlet to charge. The issue is the USB connection. It is worn out or loose due to the frequent use it gets when charging the battery every 4 hours :shock: What happens when i plug it in is it does not connect via PC and when in wall mode the green light does not come on and only does when i jiggle the connection. I essentially have a flat battery and no way to charge it.
I want a refund, is the short and sweet of it, or at least a new replacement unit. Of course I will be expecting not to get the postage cost repaid for sending it back to them!!
Anyone wanna give me any advise, will Uxcell stand by this sort of Warranty issue??
Cheers
Joffa
White Super i Platinum 2 GB
Logic Chip
ATJ 2093 H
F8200FA 59E
LKD 9702 01
2006 - 10 - 25
FW 9. 0. 48
2006 - 9 - 12
Memory
Samsung 640
K9LAG08U0M PCB0 FEI848AX
Battery 3.7v 180 mAh
USB 2.0 A to Hirose 4 pin flat
Old 20th Jan 2007, 12:17 pm
Dear Joffa,
Sorry for any inconvenience caused.
Would you mind giving me your order number please ?
Yours sincerely,
Keith
UXcell.com
Old 20th Jan 2007, 3:55 pm
Default Re: Player return to Uxcell
HI Keith
My order number is
ORD20061225472
cheers
Joffa
Logic Chip
ATJ 2093 H
F8200FA 59E
LKD 9702 01
2006 - 10 - 25
FW 9. 0. 48
2006 - 9 - 12
Memory
Samsung 640
return my mp3 player or not? Ack General Discussion 3 20th May 2007 12:35 pm
Want to return my player but not sure if I'll get money back Relikk Miscellaneous 6 14th Feb 2007 10:46 pm
Avi Player from Uxcell whitedragon General Discussion - Uxcell.com 11 12th Feb 2007 2:10 pm
Is it worth the headache of a return??? chino_morino General Discussion 1 27th Jul 2006 7:35 pm
Received my return for defective unit. Gave me 2gb vs1gb! Rocker81 Support and How To 6 24th Jul 2006 9:48 am
