still no reply about silver platnum problem
Old 25th Jan 2007, 5:43 pm
Default still no reply about silver platnum problem
now I got another problem with my ebay ceo1shop , which came from uxcell, silver platnum and still no replies to my emails. The screen just flickers with the hourglass screen for a few seconds and shuts off. I have tried to charge it with the switch on and off but still nothing.
And The auction said 8 hour battery life but its only 4. their reply to that problem was that it is not constant 8 hours. with that kind of excuse it could be a month long battery life if you don't use it contantly. I did get a $5 refund for that problem though. WOWIE.
The worst ebay transaction for me so far.
Old 26th Jan 2007, 5:17 am
Default Re: still no reply about silver platnum problem
Maybe your player is in ADFU mode! When the player is in ADFU mode the screen only show the hourglass!
Try to plug it in your USB port and check what windows show!
About the battery life...did you configured the player to turn screen off after a sonug is playing? the screen will be off but the player will be on and the battery time will be longer!
Old 26th Jan 2007, 6:17 am
what do you mean whatch what windows show? what am I looking for? and it flashes the hourhlass picture. what is adfu mode and how do I get rid of it?
yes I configures it to shut the screen off after 5 seconds. my old player that I got from ebay actually did play 8 continous hours but not these ones.
Old 30th Jan 2007, 1:27 pm
After you plug it in USB port appear a green arrow next to windows clock, double click in green arrow, then you can check if the player satus is MASS STORAGE DEVICE or ADFU MODE.
If player is in ADFU mode you only can repair it getting the firmware dump.bin (but you must to take care, you can kill your player) and it is not easy to find...you have to open your player and get the board especification, check www.s1mp3.org.
If player satus is Mass Storage Device and the screen still showing hourhlass picture, sorry I don't know what it could be!
Old 30th Jan 2007, 3:58 pm
dersquaw, Have you tried to PM Keith here at MyMPxPlayers.org. If the ebay shop is one of Uxcells trading names I am sure he will help you if he can as he has quickly fixed many problems that Uxcell customers have had.
http://www.mympxplayer.org/privmsg.php?mode=post&u=6114
Reply from Hong Kong Supplier...what next???? pjgodman Dead Players 4 13th Dec 2007 9:16 am
dead platnum oakbrother General Discussion - Uxcell.com 1 3rd Oct 2007 3:34 pm
My i-platnum hanged luvarun General Discussion - Uxcell.com 6 10th Mar 2007 9:42 pm
Item lost and UXCELL WON'T REPLY! condensercl General Discussion - Uxcell.com 6 21st Jan 2007 5:04 pm
reply on amv tool nerdboia Support and How To 3 29th Mar 2006 11:50 pm
