longer battery life
is there any way of enhancing the battery life of a player? im still waiting for my palladium to arrive, i was wondering if the battery is integrated in the player or i can purchase another battery to slip in when the first one is over...
thanks, marco. |
marcolo86 , the usual way is to set your player to switch the screen off when the player is idling. The screen uses quite a significant amount of power.
Likely i think the Palladium has an integrated battery. As they never mentioned the removeable Nokia battery option. |
thanks for the reply! looking forward to using it...do you by any chance know if it is a good product?
bye! marco. |
marcolo86 , i'm not very sure of it as i don't own one of those. But it should generally be the same as the rest, as the chipset is the same.
| All times are GMT -7. The time now is 10:15 am. |
