Changing my screen
Old 1st Feb 2007, 7:25 pm
Default Changing my screen
I have a super-i-platuinum and I want to know if anyone can tell me how to view my screen vertically instead of horizontally.
Thanks for help
Old 1st Feb 2007, 7:52 pm
Da_smashman, you would have to change firmware, but chances of you finding a compatible firmware for thr player are not good. Chances of bricking your player trying are great.
If you player is running 9.0.48 and above you may not be able to recover it if it does die.
Old 1st Feb 2007, 9:51 pm
Thanks for help
Try changing the settings in AMV.There's tutorials here on that.
White screen, doesn't get recognised after changing firmware fish neck Firmware 7 16th Mar 2008 7:47 pm
changing the theme OdangoAtama Mods and Themes 1 13th Nov 2007 10:37 am
Changing MP3 Bitrate.. gtp300hp Support and How To 3 28th Jan 2007 9:18 am
Changing the Menu Screen indikit Mods and Themes 3 27th Dec 2006 7:33 pm
Changing I-Platinum Jr. 1GB Startup Screen firmware 9.0.48 swfx Mods and Themes 3 22nd Dec 2006 9:37 am
