-   General Discussion - Uxcell.com (http://mympx.org/forum/general-discussion-uxcell-com/)
-   -   I-Platinum problems (http://mympx.org/forum/general-discussion-uxcell-com/36560-i-platinum-problems.html)
huginn 9th Feb 2007 5:00 pm
I-Platinum problems
Well i have an I-platinum from uxcell
it will not turn on i hold the play button for "long" period of time nothing
i tried flicking the on / off switch to off holding down the pause button and flicking the switch back to on and i saw a blue screen with an hour glass
as soon as i let go it went black again i tried again and eventually realized that it would only turn on when i held pressure on the on / off switch at the top like actually pressing down on it i dont think this is the intended functionality heh i cant even get it to flick on now tho maybe i pressed it down too much? i dont know but i plug it inot my computer and nothing happens it was showing up last night when i help down the on / off switch
BLECH any suggestions?
lattesurf 10th Feb 2007 5:50 am
huginn , likely the on/off switch at the top has its solder broken off, or the switch is physically damaged.
Perhaps you could contact uxcell for a replacement player.
