i-platinum problems
Old 19th Feb 2007, 10:27 am
Default i-platinum problems
i just got an i-platinum from uxcell, xp used to identify it, but now it wont. player still turns and works. when plugged in it shows the connect screen, but it doesn't let me get into its file system.
Old 27th Feb 2007, 4:46 am
Default Re: i-platinum problems
Hello, I have the same problem with my i-nickel since i bought it. XP recognises it when it wants to. It took me over an hour yesterday for Xp to read the player. I have to disconnect it and reconnect a hundred times on the off chance that xp will pick it up. Occassioanlly it gets picked up but shows no files on the player and it will not allow you to add any files. Eventually i managed to get it working but half way through loading it up, it just stops again.
One thing that helps is to have it fully charged, there is more chance of it being picked up by XP. Is there any drivers for XP as this seems to be the answer to why it is not being found.
Platinum V3 mq1991 General Discussion - Uxcell.com 1 16th Sep 2007 10:13 pm
i-platinum 1.8 pfer Mods and Themes 3 4th May 2007 6:18 pm
Full Metal Platinum 2gb 1.8 - Problems fraimond General Discussion - Uxcell.com 2 1st May 2007 9:54 pm
I-Platinum problems huginn General Discussion - Uxcell.com 1 10th Feb 2007 5:50 am
i-Platinum/Super i-Platinum/Baby Nano/i-Platinum Junior? nanocopyuser General Discussion - Uxcell.com 1 17th Jan 2007 12:27 am
