Glacier battery life with Nokia BL-4C
Old 20th Feb 2007, 1:28 pm
Default Glacier battery life with Nokia BL-4C
As mentioned in my other post:
http://www.mympxplayer.org/2-gb-glac...em-vt3979.html
I have completed back to back tests of the Uxcell supplied Glacier battery (BL-4C compatable) and a genuine Nokia BL-4C.
Uxcell - 3.5 hrs on constant video play (vol 17 through headphones)
Nokia - 6.5 hrs on constant video play (vol 17 through headphones)
Will try with MP3 playback but am guessing that the Nokia should provide almost 20 hrs. This is based on Hotboxx's findings that Uxcell battery lasts 10.5 hrs on MP3 with display off.
The genuine Nokia is a "factory reconditioned" one.
Old 20th Feb 2007, 1:32 pm
Nice - I only wish that MY glacier would hold a charge. I have no idea what's wrong with it. I fully charge it, turn it off using the play button, and the next day it's completely drained. Only if I completely turn off using the power switch does it hold a charge. I've tried this with two different batteries with the same results. It's annoying to constantly use the switch, so does anyone have any suggestions on how to improve battery life so that it lasts as long as timdoggy's player? Thanks.
Old 20th Feb 2007, 1:55 pm
With display off I had a 10 1/2 hour nonstop playtime with the Uxcell Battery
With the (supposed) 1700mAh I had a 12 1/2 playtime.
Old 20th Feb 2007, 2:06 pm
Sorry to hear of your problem, not had mine long enough to know whether it will gradually power down.
Whilst I am in updating mode, dunno if anyone cares, however the genuine Nokia battery is heavier (perhaps half as much again) as the Uxcell one.
Guess its cos they have crammed in all those extra MilliAmps :roll:
Old 20th Feb 2007, 4:36 pm
Default Re: Glacier battery life with Nokia BL-4C
Thanks for the review on battery times. Can I ask where you bought your Nokia battery?
I may get one if the price is right.
Old 20th Feb 2007, 8:55 pm
I got mine from eBay seller: fc_onlinestuff
Seller was very nice to me, and the cost was only $6US shipped.
Old 20th Feb 2007, 10:34 pm
MPx-a-lolics Anonymous
thanks for the review timoggy
Old 21st Feb 2007, 2:44 pm
I got it from:
http://www.qfonic.com/product_info.php?products_id=1137
I do not know if they deliver to Canada. It cost me £6 (inc delivery). If you can source one a bit more locally (US?) as michiganjfrog notes you will probably get one cheaper.
As its a factory reconditioned one, it has a few marks on it. Seems to work OK so far though.
8GB 2" TFT MP4 MP3 WMA FM PMP PLAYER USB NOKIA BATTERY pavuckar Support and How To 1 4th Dec 2007 1:09 am
How to use a nokia battery in chinese mp4 handy player ?? ritul Support and How To 0 3rd Jul 2007 5:44 am
Nokia Battery... joossiej General Discussion - Uxcell.com 28 8th May 2007 7:09 am
Nokia battery in player korn88 General Discussion 4 3rd Mar 2007 7:02 am
Spotted another MP4 player with Nokia battery michiganjfrog General Discussion 3 23rd Feb 2007 10:08 am
