Glaciar keypad material same as RAZR V3?
Old 27th Feb 2007, 4:19 pm
Default Glaciar keypad material same as RAZR V3?
Is the Keypad on the Glacier the same feel as on the RAZR V3? looks to be made out of aluminum though...
Old 27th Feb 2007, 4:39 pm
Default Re: Glaciar keypad material same as RAZR V3?
the material that mine is made out of is aluminum, im pretty sure that its a plate attached to plastic internally so that it can reach the switch inside.
im not sure if it feels like a RAZR V3 but my friend has one and ill see if its got the same feel (somone will probably post an answer before me)
Black Bianca 2GB
Nautilus Shipped 2007-06-15, 16:18:12.0
Soprano Paid 16 Jun. 2007
Old 27th Feb 2007, 6:39 pm
I've never "felt" a RAZR V3, but having just seen a pic of it, Id say the two are similar, as it also appears to be brushed aluminum, like the Glacier.
It is indeed a plate that has cutouts that cause the metal to bend a bit and hit contacts under the plate.
no idea firmware or keypad problem ourherohasfallen Support and How To 3 11th Jul 2007 5:30 pm
