Does Uxell have a nano clone with a longer battery life?
Old 8th Mar 2007, 11:01 am
Default Does Uxell have a nano clone with a longer battery life?
I like the the nano clones available at Uxell, with one problem, all of them have a battery life less than 4 hours. Does anyone know if Uxell or any other legit seller has a nano clone with a longer battery life?
Old 8th Mar 2007, 6:52 pm
From what I've seen your best bet is, if you're handy with soldering, buy another battery (ipod nano replacement batteries?). Not sure about the details, but I'm sure someone here would know.
Proud owner of THREE cheap MP4 players - one with a broken screen (given away), one I broke personally (lesson learned: dont fix it if its is not broken), and the Glacier.
Old 8th Mar 2007, 7:26 pm
Default Re: Does Uxell have a nano clone with a longer battery life?
The Bianca model, while not a Nano clone, does reportedly have 8 hours batt life. Otherwise, you'd have to buy an aftermarket battery and find one that fits in a nano clone.
Old 9th Mar 2007, 9:44 am
I looked at the Bianca models. The description on some says 2-4 hours, and others say 6-8 hours. Photos and specs otherwise look the same (except color), I am not sure what to believe.
Old 9th Mar 2007, 12:10 pm
They're saying in the specs that its 6-8hrs on mp3 and 3-4hrs on video. A member here has reported 8hrs mp3 with his biancam which is why i assume it really is 8 hrs.
How to change BATTERY for LONGER LIFE!!! d12nv Support and How To 7 1st May 2007 1:47 am
iPod Nano Clone Battery Life aurelio General Discussion 5 30th Mar 2007 5:34 pm
Recs for nano clone - 1 or 2 GB, FM, lyrics, 3+ hr batt life speedypear General Discussion 14 7th Mar 2007 10:18 pm
longer battery life marcolo86 General Discussion - Uxcell.com 3 30th Jan 2007 7:14 am
Nano Clone Battery Life? homegrownpushbikes General Discussion 1 31st Oct 2006 5:57 am
