Question For Uxcell - ICE phone
Old 14th Mar 2007, 10:10 pm
Default Question For Uxcell - ICE phone
i see that phone on other websites and it is dualband phone. but on your site it says it is quadband. can you guarantee it will work in US? and can you tell us more about the phone? thanks in advance. im really interested in buying it.
@forumers
you think i should go ahead and buy it, and if it doesnt work, send it back?
Old 15th Mar 2007, 3:53 pm
Default Re: Question For Uxcell - ICE phone
after sending some tough emails to uxcell, it seems they have changed the specs for the Ice touch phone. used to be 850/900/1800/1900 and know its 900/1800. its a good thing i didnt purchase this, as it wouldnt work here.
Old 24th Mar 2007, 4:16 pm
dyce,
Thanks for the update.
I don't know if it's compatible in NZ. I've been told it is so I might get one myself.
Old 25th Mar 2007, 12:16 pm
Admin, THIS is what you're looking for.
The reddish area is GSM 900. There is currently no map for the coverage of the GSM 1800 area, but NZ only uses GSM 900 and 1800.
UXcell Camcorder question Lorne General Discussion - Uxcell.com 5 21st Nov 2007 2:20 pm
First look at MP4 PDA/Cell Phone razzer001 General Discussion 0 3rd May 2007 4:07 am
Question for UXCELL on Rhodium 1Gb VisiGoth General Discussion - Uxcell.com 0 24th Mar 2007 4:25 pm
The new PHONE - MP4 Player with touch screen on UXcell! xenocarcinus General Discussion - Uxcell.com 9 3rd Mar 2007 10:50 am
phone book geostar1711 Support and How To 0 29th Jul 2006 11:10 am
