Nokia Battery...
Old 23rd Mar 2007, 12:32 pm
Tried a BL5C in my Glacier today and it worked ok, but it wouldn't charge.
I kept getting a cryptic message about turning the Glacier on when charging.
Put the original battery in and it charges without problem.
Also, does anyone know if the Glacier can be charged via USB connection to a PC or using a standard USB charger other than the very cheap supplied one?
Old 24th Mar 2007, 12:23 am
Default Re: Nokia Battery...
It comes with a cable to connect it via USB to your pc and charge it.
You can also get a better quality charger for the bl4c on eBay or mp4nation has a 500mah one.
Old 25th Mar 2007, 7:43 am
You're supposed to have the Glacier in the On position when charging it.
If you find that the battery isn't charging, that means the charger isn't giving it enough juice.
Buy an after market charger on ebay for a few dollars.
Michigan, I bought my BL-5C battery on ebay for 6 bucks. Shipped.
Old 25th Mar 2007, 11:43 am
seraphim: have u got a link to the bl5c? they may not all be equal...
Old 25th Mar 2007, 12:02 pm
LOOOOOOOOOOOOOOOOOOOOOOOOOOOOL
well... BL-5C is not rounded... is more like a matchbox... but rather thin
  #16 (permalink)
Old 25th Mar 2007, 12:12 pm
The BL-5C stats can be found with an easy Google search. The first 2 links are probably on Nokia's sites. You'll find they give two difference mAh rating, but I think that's because there are two model Samsung batteries rather and just a goof in the data online.
If you search ebay for Ikeym you'll find the guy I bought my battery from.
I'm not sure what the other posters "LOOOOOOL" was all about. If you'd care to try again in english perhaps I can answer the question?
  #17 (permalink)
Old 26th Mar 2007, 6:11 am
LOL = Laugh Out Loud
LOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOL = a long one
  #18 (permalink)
Old 26th Mar 2007, 10:29 pm
I'm almost sure there's a question in there. I've asked many people in my counterstrike clan to help decipher "LOOOOOOOOOOL" in the hopes you're asking a question or making a shakespearian declaration of such a profound nature my mind will melt.
But I think you're just padding your post count.
  #19 (permalink)
Old 27th Mar 2007, 5:41 am
Are you talking of Shakespeare the painter?.
The long LOOOL was a reaction to somebody's question asking if Nokia BL-5C is proper Nokia battery BL-5C.
AFAIK Nokia batteries (or Samsung if you wish) adhere to stricts specifications concerning size and power... what other Nokia battery BL-5C can be then?
  #20 (permalink)
Old 27th Mar 2007, 10:30 am
Pfft , Writing silly messages to add to their post count , Immature
8GB 2" TFT MP4 MP3 WMA FM PMP PLAYER USB NOKIA BATTERY pavuckar Support and How To 1 4th Dec 2007 1:09 am
Nokia battery in player korn88 General Discussion 4 3rd Mar 2007 7:02 am
Spotted another MP4 player with Nokia battery michiganjfrog General Discussion 3 23rd Feb 2007 10:08 am
Glacier battery life with Nokia BL-4C timoggy General Discussion - Uxcell.com 7 21st Feb 2007 2:44 pm
Player with Nokia-compatible battery - does it deliver ? Raider_MXD General Discussion 18 7th Feb 2007 7:31 am
