Nokia Battery...
  #21 (permalink)
Old 27th Mar 2007, 10:30 am
  #22 (permalink)
  #23 (permalink)
Old 27th Mar 2007, 10:31 am
  #24 (permalink)
Old 27th Mar 2007, 5:04 pm
Originally Posted by DaremoS";p=&quot View Post
In fact BL-4C fits right in an Mp4 rockchip player.
But I have done the same that Seraphim making fit a BL-5C into my device by making it more thin.
It worth the effort. Nokia battery (in fact is a Samsung battery) last at least three times the original chinese battery.
Rockchip device demands more battery than an Ipod clone. Manufacturer put a special remark about this, how is to s switch off the device when it's not in use.
I find out that is a Samsung battery because in the process of make the BL-5C fit in my machine I remove Nokia cover, now is a silver battery with a small Samsung marked on it.
Not a Nokia anymore :P
Yesterday I've tried the BL-5C of a friend's Nokia mobile phone and it doesn't fit into the Glacier.
Does the BL-5C have a plastic case that I can remove to fit the battery into the Glacier?
Otherwise I would by an original Nomia BL-4C, this should double the playback time compared to the chinese battery, too.
  #25 (permalink)
Old 27th Mar 2007, 8:25 pm
Default Re: Nokia Battery...
I thought I mentioned that I modded my battery and the housing on my Glacier. I'm sure I mentioned that.
Battery, take off the 'wrapper' and sand down the black plastic bit.
Not for the faint of heart.
  #26 (permalink)
Old 14th Apr 2007, 2:23 pm
xad xad is offline
how many hours of playback would a bl-5c battery give on a device like the Glacier?
  #27 (permalink)
Old 15th Apr 2007, 11:15 pm
anyone tried a BL-6C ? im about to order one =D, hopefully it fits
Black Bianca 2GB
Nautilus Shipped 2007-06-15, 16:18:12.0
Soprano Paid 16 Jun. 2007
  #28 (permalink)
Old 15th Apr 2007, 11:35 pm
ive got a glacier like thing , you know the one with the 2 speakers and sd slot on it , it has a 1.8" screen and 2 headphone ports , its a sun chipset , i have the BL-5C battery in it ( tight squeese) and it runs well over 20 hours . i left it on last night for 12 and still showing 75% battery left
  #29 (permalink)
Old 8th May 2007, 7:09 am
Okay, I have some questions.
I am about to order a Glacier and a pair of BL-4C and a BL-5C battery.
Question1:
Can you post a step by step guide how to fit the 5C?
Question2:
Will the 5C charge properly? (Without another recharcher - mabye USB?)
Question3:
How long will the 4C last, because I have read that the original Glacier battery lasts 4 hours. Is a 4C worth it?
Question4:
Is there a way of fitting the 5C in it perfectly and can you take off the whole case to put it in?
Thank you, hope I am not bothering you
8GB 2" TFT MP4 MP3 WMA FM PMP PLAYER USB NOKIA BATTERY pavuckar Support and How To 1 4th Dec 2007 1:09 am
Nokia battery in player korn88 General Discussion 4 3rd Mar 2007 7:02 am
Spotted another MP4 player with Nokia battery michiganjfrog General Discussion 3 23rd Feb 2007 10:08 am
Glacier battery life with Nokia BL-4C timoggy General Discussion - Uxcell.com 7 21st Feb 2007 2:44 pm
Player with Nokia-compatible battery - does it deliver ? Raider_MXD General Discussion 18 7th Feb 2007 7:31 am
