Nokia Battery...
Old 17th Mar 2007, 2:42 am
Default Nokia Battery...
Does this Nokia Battery works with my Glacier? And why should I buy this?
More hrs? Check Here
Old 17th Mar 2007, 5:54 am
im pretty sure the Nokia BL-5C batteries don't allow the back cover to fit on with the glacier. im sure someone will confirm this
Black Bianca 2GB
Nautilus Shipped 2007-06-15, 16:18:12.0
Soprano Paid 16 Jun. 2007
Old 17th Mar 2007, 5:58 am
Default Re: Nokia Battery...
K So it doesnt work? Can somebody plz confirm that ? And give me a link to a battery that works on the Glacier?
Old 17th Mar 2007, 10:40 am
the one that fits the Glacier is the BL-4C
Proud owner of THREE cheap MP4 players - one with a broken screen (given away), one I broke personally (lesson learned: dont fix it if its is not broken), and the Glacier.
Old 18th Mar 2007, 2:03 am
k can you give me a link :mrgreen: ?
Old 20th Mar 2007, 8:53 am
I have a BL-5C working in my glacier now.
You are correct, that the back will not fit completely on, however if you use a good knife to cut one of the retaining tabs on the front of one side, the battery will slide on snuggly with a slight bulge at the top mid portion of the battery cover.
It's not very noticable unless you turn the player sideways and look for it.
I wanted to give it a try because of the large difference in milliamp hours that the 5C offers over the 4C.
I've had it playing WMA files for the last 2 hours, and will see how long it plays.
Old 20th Mar 2007, 8:21 pm
Id also be interested to know how long a 5c lasts. It would seem cutting one of the tabs compromises the ability of the back cover to stay on, no? Perhaps removing the battery's paper label might also help.
Old 22nd Mar 2007, 12:29 pm
Well I fell asleep at the 16 hour mark, so I don't know how long it lasted.
Old 22nd Mar 2007, 3:17 pm
In fact BL-4C fits right in an Mp4 rockchip player.
But I have done the same that Seraphim making fit a BL-5C into my device by making it more thin.
It worth the effort. Nokia battery (in fact is a Samsung battery) last at least three times the original chinese battery.
Rockchip device demands more battery than an Ipod clone. Manufacturer put a special remark about this, how is to s switch off the device when it's not in use.
I find out that is a Samsung battery because in the process of make the BL-5C fit in my machine I remove Nokia cover, now is a silver battery with a small Samsung marked on it.
Not a Nokia anymore :P
Old 23rd Mar 2007, 11:44 am
Did you say 16 hrs?! Where did you get your BL5C from?
8GB 2" TFT MP4 MP3 WMA FM PMP PLAYER USB NOKIA BATTERY pavuckar Support and How To 1 4th Dec 2007 1:09 am
Nokia battery in player korn88 General Discussion 4 3rd Mar 2007 7:02 am
Spotted another MP4 player with Nokia battery michiganjfrog General Discussion 3 23rd Feb 2007 10:08 am
Glacier battery life with Nokia BL-4C timoggy General Discussion - Uxcell.com 7 21st Feb 2007 2:44 pm
Player with Nokia-compatible battery - does it deliver ? Raider_MXD General Discussion 18 7th Feb 2007 7:31 am
