what is the rite firmware for full metal platinum 1.5
Old 26th Mar 2007, 9:02 pm
Default what is the rite firmware for full metal platinum 1.5
i bought an mp4 from UXCELL and used it for about 2 days and it froze now i am trying to find and firmware to upgrade i have tried the firmware they have given on their website when i update it my player just shuts off and turns back on, but there is no other movement other than just a bluew screen comes up, it is detected as a flash drive i can upload stuff on it but that is it i cant listen anything on it or maybe there is not firmware on it, and i cant find the rite firmware either, so can somebody plz plz plz tell me where can i get the rite firmware from?? i have tried some ov the firmwares listed on this side but there is still no moovement in the player :?: :evil:
Old 26th Mar 2007, 9:25 pm
The FMP 1.5 uses fw 9.0.48. The versions on UXcells website are not compatible with it, so you've basically 'killed' your player by 'upgrading' it's firmware. The one you have flashed it with is for the FMP 1.8.
Flashing the firmware should always be your LAST option when something goes wrong. version 9.0.48 cannot be extracted from other players either making your chances of recovering of your FMP slim to remote.
You only option now is to get your hands on as many fw 9.0.48's and peform the dead player recovery.
[hr:43af44b395]
Old 27th Mar 2007, 1:02 pm
Default Re: what is the rite firmware for full metal platinum 1.5
it was dead but then after i opened it and did whatever was said in the dead player recovery guide and all i saw on it was a blue screen and thats it
Full Metal Platinum 1.5 - Firmware needed womblebongo General Discussion 10 31st May 2007 2:42 am
Full Metal Platinum....? BisonMami General Discussion - Uxcell.com 39 20th Mar 2007 2:48 am
full metal platinum 1.5 vietnamesetan General Discussion - Uxcell.com 0 20th Feb 2007 1:45 pm
Full Metal Platinum 1.8 Red Deckar General Discussion - Uxcell.com 2 5th Feb 2007 8:37 am
Full metal Platinum Joffa General Discussion 1 3rd Feb 2007 8:33 pm
