Headphones On Uxcell
Old 31st Mar 2007, 8:06 am
Default Headphones On Uxcell
I was thinking of buying this headphone in uxcell.
http://www.uxcell.com/uxcell/retail/...06060700ux0003
But Im not sure if it will fit on my nano clone. So can any1 help figure it out. Helps will be appreciated.
Old 31st Mar 2007, 9:23 am
You have to read your player especification and see wether it has a 2.5mm or a 3.5mm earphone plug.
You could know it only by seeing it, however if you don't, just see the especifications.
Old 2nd Apr 2007, 8:04 am
Where do I find the specifications?
Old 3rd Apr 2007, 10:03 am
you should also worry if they fit your ears. they look like the ones they sell with the player and there's no way those can fit in human ear
Old 21st Apr 2007, 6:09 am
Default Re: Headphones On Uxcell
Those look like the same ones that came with my player. If they are then thay are crap. I purchased a pair of ebay for $4 that were three times better.
Best sounding in-ear headphones I've used. Buzzygirl General Discussion 0 28th Sep 2007 10:57 am
Headphones arucart Support and How To 14 22nd Aug 2007 7:29 am
quality headphones jkeene General Discussion 1 8th Apr 2007 4:43 pm
Headphones! nidebaba General Discussion 3 20th Feb 2007 7:26 am
Those CHEAP headphones! Dean786 General Discussion 4 31st Dec 2006 2:58 am
