Glacier charging!!!
Old 4th Apr 2007, 5:02 am
Default Glacier charging!!!
Hello, I am new to the forum and was wondering the sequence of charging a 2 GB Glacier with the wall charger?
After I charge with the wall charger my computers usb detect the Glacier( safety removal) but then just disappear from my computer screen and so does the safety removal.
Is ther a certain sequence to remove the Glacier from the wall charger kind of like the safety removal of windows does for the Glacier?
The player works good otherwise if I use the usb port to charge but I think it charges better with the wall charger.
How long should it charge for in the usb mode and the wall charging mode with a 500mA charger.
Also how long should the battery last in the glacier watching a movie with headphone on middle volume?
Thanks everyone for the replys.
Old 4th Apr 2007, 6:27 am
Only thing you have to do is to switch the Glacier on while charging.
And your USB problem: You only can connect to the Glacier when you see the "Connect" screnn on it. If you enter the menu, the Glacier will disappear in Windows. Don't press the M key while data copying!
Glacier Repair Toolkit - How to fix glacier player alex2pb Support and How To 14 16th Dec 2008 1:51 am
2gb Glacier - Charging Question ForeverSpyder General Discussion - Uxcell.com 0 24th Jul 2008 10:19 am
Charging Michael Support and How To 8 20th Jul 2007 9:37 am
First charging. botzon Support and How To 5 17th Jan 2007 10:56 am
LCD off while charging. tadad1 Support and How To 0 2nd Jun 2006 9:45 pm
