Glacier Firmware Update... and my player was died...
Old 19th Apr 2007, 2:13 pm
Originally Posted by silverman";p=&quot View Post
hi Omijam
Atj2093 Firmwire 2" 1&2gb
Download Firmwire Oke ?
dude you saved my player too thanks! <3
and I can install themes now too! :P
BEST MP4 I''VE EVER SEEN:
http://www.youtube.com/watch?v=RwFeiNXjFhE
(c) Sersoft.corp All rights Hacked...
Old 22nd Apr 2007, 10:09 am
Hello my glacier has firmware 9.0.51 ACT 2093-S75
Do you know a link to get that upgrade?
My unit will not accept files they all come up as wrong format.
Thanks Doug
Old 22nd Apr 2007, 11:15 am
Default Re: Glacier Firmware Update... and my player was died...
Thanks Doug
Hi.
Maybe the Problem is in the ID3Tag v1. At first Start of my player I've uploaded MP3 files with an corrupt ID3Tag and wonder why my Player shows me ACSII Codes as Titel.
Maybe you try www.mp3tag.de to change or delete the Tags
Old 22nd Apr 2007, 1:10 pm
Thank You for the reply. That is not it because it did it with all files AMV and JPEG pictures as well.
I did download the link posted by silverman and used it but it is 9.0.50 not the 9.0.51 that was in the player. It did work after some scary moments getting it back to English from Chinese after the upgrade. It seems now the MP3 players is only 1GB instead of the 2GB it came as so I am thinking it was hacked and that is why I had the problem after it was 3/4ths full.
I am looking for the 9.0.51 firmware because that was the original that was in it but it seems to work fine with the 9.0.50 firmware just a fews things work differently.
ThankYou all it seems these units are great if you are know your way around a computer and are not afraid to try things.
Old 19th May 2007, 2:50 am
hi i have a problem with mp4 glacier too. I wanted to install a new firmware, cause I wanted to solve my problem with adapter.
I did format with MP3 Utilities 4.05.
I've downloaded the firmware file from Uxcell site, the Glacier 9.0.48 firmware version. I've followed all steps described in the instructions sheet.
Then it wanted to Windows XP´s format, and when I´d format, in my glacier appeared new files, with crazy change´s dates and crazy names.
Currently it appeared a file system RAW. What can I do with?
  #16 (permalink)
Old 21st May 2007, 10:33 pm
hey all PLEASE help me fix my glacier mp4 cuz i loved it so much
first , i got the hourglass
second , i upgraded it with a wrong firmware and it show only a white screen and by the way i tried soooo many firmware versions and they all do the same thing
the program says "the upgrade is success, now the program will exit!"
and nothing happen, just when the program says this message my mp4 player disconnects automatically.
what can i do ???
what firmware should i use pleeeease?
what program should i use too?
Thanks, any help will be soooo appreciated
  #17 (permalink)
Old 29th Jun 2007, 9:59 am
Hello, I've the ATJ 2091 chip and also 4 dead players with that chip. Can anyone help me how to fix them. The screen came white.
  #18 (permalink)
Old 15th Nov 2007, 11:46 am
Hi all,
i also firmwire updatet my 4gb glacier. but after a few tries, the screen went black.
it doesn't work anymore. even my computer doesn't see it anymore so i cant try another firmwire update
can someone help?
thnx!
  #19 (permalink)
Old 21st Jun 2008, 7:44 pm
Thanks Doug
I Love This Site
  #20 (permalink)
Old 5th Oct 2008, 3:06 pm
hi, i've got a glacier player but it doesn't work, i tried to find the correct firmware but i couldn't get it, the chip is a atj2091n, and the main board is a qy-066fv0 2007.05.11, does anybody has the firmware?
glacier like mp4 ak1025 need 9.1.52 firmware UPDATE bladerunnerx_x Dead Players 6 2nd Apr 2008 5:36 am
2Gb Glacier- F/W update- White Screen micl1 General Discussion - Uxcell.com 1 12th Feb 2008 4:24 pm
my rockchip mp4 not died but can't update firmware sid2512 Dead Players 0 8th Jan 2008 1:41 am
my rockchip mp4 not died but can't update firmware sid2512 Dead Players 0 8th Jan 2008 1:39 am
Update on my (previously dead) glacier oldschooljohn General Discussion - Uxcell.com 3 21st Feb 2007 7:09 pm
