-   General Discussion - Uxcell.com (http://mympx.org/forum/general-discussion-uxcell-com/)
-   -   voltage rating of I-nickel battery (http://mympx.org/forum/general-discussion-uxcell-com/37863-voltage-rating-i-nickel-battery.html)
VRaptor 30th Apr 2007 5:00 am
Just recieved my I nickel MP4 player from UXCELL. charged the battery and used it til the battery needed charging again but it will not accept a charge now from usb or the wall charger. I am going to try to find a repalcement locally but the battery has no markings so I need to know what the voltage rating is. I have noticed that a lot of players run off of a 3.7 volt battery. Is the I-nickel the same. Any help will be greatly appreciated :)
lattesurf 30th Apr 2007 8:11 am
VRaptor , these players generally use 3.7V batteries. You can find many of them on ebay/uxcell or some electronics stores.
VRaptor 30th Apr 2007 1:03 pm
Thanks for the reply. I'll see what I can find at radio shack
