Full Metal Platinum 2gb 1.8 - Problems
Old 30th Apr 2007, 11:34 am
Default Full Metal Platinum 2gb 1.8 - Problems
Guys....
I am posting looking for a bit of advice. Having purchased the above named player from uxcell I recently got to put mp3s onto the player. I have loaded 122 songs using "copy to other device" on media player.
When I right click drive F and select properties it says I have 1.9gb of space. 1.41gb which is free and 503mb of which is getting used.
Now when I goto put more files/songs onto the player it says "error copying file or folder - the directory or file could not be created"
Just looking for a bit of advice. Thanks
Old 1st May 2007, 9:16 pm
Try low formatting? Sometimes the memory would register as 'used' while it's not due to static/shorting and whatnot.
Old 1st May 2007, 9:54 pm
fraimond, Media Player seems to cause problems with most of these no-brand players. As "bleakill" has posted give it a format but be sure to backup any files you want to keep beforehand.
The less problematic way to transfer files is to connect the player and copy and paste from your music library to your player within Explorer or you could place a shorcut on your desktop to the players Music folder and then just drag your tracks to the shortcut when your player is connected.
2gb Full metal platinum 1.8 fraimond Support and How To 0 30th Apr 2007 11:35 am
Full Metal Platinum....? BisonMami General Discussion - Uxcell.com 39 20th Mar 2007 2:48 am
full metal platinum 1.5 vietnamesetan General Discussion - Uxcell.com 0 20th Feb 2007 1:45 pm
Full Metal Platinum 1.8 in Red Deckar General Discussion - Uxcell.com 1 15th Feb 2007 8:39 pm
Full Metal Platinum 1.8 Red Deckar General Discussion - Uxcell.com 2 5th Feb 2007 8:37 am
