Batterie problems with I-Nicel
Old 15th May 2007, 11:07 am
Default Batterie problems with I-Nicel
Hello
I bought few weeks ago a 2GB I-Nickel player , for one of my friends.
I gave him, and the next morning , he told me that the batteries just holded 1 minute , the next morning, even after an USB full recharging ! It seems that the battery is emptying when the player is OFF !
This is strange because I never heard about such a problem ! I have a Chipod Nano (buyed @ Ebay, really 4Gb memory ) , turned it off 3 weeks ago, turn it on today, and it have still batteries !
So, what should I do ? send it back to UXcell ?
Thanks a lot for your responses , and sorry for my english ! :roll:
PSP : 3.03 OE-C
MS : 1GB + 2GB + 4GB
XMB : Encore 4 + Hykypoo''''s Icons
Old 15th May 2007, 11:50 am
Sending it back to uxcell would cost you more than the player itself. Maybe you should try to change the battery?
Meizu M3 4Gb owner.
Old 15th May 2007, 12:12 pm
Default Re: Batterie problems with I-Nicel
I don't know, because i'm really bad for all these things like changing batterie, I'm not able to use my hands correctly (as we say in french, maybe also in english : " I have 2 left hands ")
Hum ... I don't know what to do ^^ I'll search for tutos to see how change correctly the batterie ! Do Uxcell sell batteries for I-Nickel ? I have'nt found them on Uxcell ... ops:
PSP : 3.03 OE-C
Old 15th May 2007, 12:56 pm
hmmm...maybe find a battery on eBay and mail the seller to see if it is the same size ^^
Meizu M3 4Gb owner.
Old 16th May 2007, 12:01 am
Spooks
Have you tried using the wall charger?
Before you do anything you should also try using another computer, another USB port or try using a different/new cable.
[hr:43af44b395]
Old 17th May 2007, 4:51 am
I don't know why, but when I tried to charge it with the USB cable, when I turned it ON, there was a loading screen, 1 seconds later in turned off, the again the loading screen, then it turned of [...] dozen of time !
I took the USB cable away, turned it off, turned it on, put the cable in, charge it 2 hours, tested it ... an no batteries problem oO !
So, my problem is solve ... i don't know how a did it, but it's solve !
Thanks a lot for your help ops:
(PS: I hesitating to sell back my Ipodnanoclone 4GB , to buy a 4Gb Glacier ... but I heard so many bad stuff about the Glacier ... what should I do ? Buy a glacier, or continu using my ChIpod Nano ? :?: :roll: )
PSP : 3.03 OE-C
Problems with new mp4 al pal Support and How To 4 5th Nov 2007 5:03 am
MP4 Problems mark2 Dead Players 18 2nd Feb 2007 11:01 pm
problems with vl-547 dp Support and How To 2 25th Sep 2006 10:47 pm
PTA. Has to much problems PTA Video related 5 19th Jul 2006 7:25 am
AMV 4.00 problems max2 Video related 10 1st Jul 2006 2:59 am
