Uxcell 1.8" 2GB firmware problems - please help?
Old 23rd Jul 2007, 8:11 am
KB
Guest
Posts: n/a
Default Uxcell 1.8" 2GB firmware problems - please help?
I have a 2 GB 1.8" Full Metal Platinum mp3/mp4 player, and after flashing the firmware (incorrectly), I too see the blasted white screen. I have tried to download the proper firmware from the uxcell site, but after flashing both versions (1 and 2), I still get the white screen and absolutely no functionality.
Can anyone point me toward firmware
LSD_9312_10
9.1.50
My model number is mv0sil2048mp048
I can't seem to find model mp048 on the uxcell site anymore. I can find mp0478 and mp049, but not the one I"m looking for.....
Please help! Thanks so much.
Kyle
Old 11th Aug 2007, 6:51 am
Default Re: Uxcell 1.8" 2GB firmware problems - please help?
A while back I downloaded this from their site: "firmware_mp048_full_metal_1.8inch" but inside the folder are two firmware versions with titles:
LST-046A(XCELL).bin
LST-046.BIN
Are they the FW you've tried?
If not get them here:
http://www.sendspace.com/file/q8ahfu
Otherwise:
- Keep trying all FW with platinum in the title
- More FWs: http://www.mympxplayer.org/actions-9...mare-dc37.html
- before downloading to player first open each FW with s1res http://www.mympxplayer.org/s1res-v19-df349.html
You can quickly see if the FW has similar images to the one that you had.
good luck!
Problems with transferring songs and "bad disk" me Tren Support and How To 0 25th Jul 2008 1:47 am
Problems with videos - "format error" tcsgirlie Video related 5 20th May 2008 2:57 pm
uxcell i-platinum 2gb 1.5" firmware and dump files dfales13 Dead Players 0 9th Apr 2007 3:46 pm
Firmware i-Platinum 2 GB 1,5" bought from Uxcell Zanco General Discussion - Uxcell.com 14 6th Jan 2007 12:46 pm
Is a General "problems" Thread needed? (and a prob Innomen Support and How To 2 3rd Aug 2006 11:59 am
