Need help identifying (and upgrading) my MP4 Player
Old 30th Aug 2007, 3:18 am
Default Need help identifying (and upgrading) my MP4 Player
Over a year ago, I purchased an MP3/MP4 Player from UXCell... I believe the model was called something like 'The MiniDiamond'. I'm looking for a proper make/model if one exists, just so I know what to search for.
Details:
1 Gig memory
Black metal casing (full body)
Dimensions are roughly 1.5"x1"x.25"
Screen is 96x126 pixels, but only supports 96x96 movies/images due to a band that runs across the bottom
Front features screen only, no buttons
Left hand has REC, MODE, PLAY, |<<, and >>| (in that order)
Right hand has Vol-, Vol+, Power Switch, and MiniUSB port.
Audio plug is on top
Firmware Version Reads:
ACTS16D_13
2005/06/01
WS-3.2.13
2005/11/10
I wish I could tell you more, but unfortunately I no longer have the emails and UXCell no longer appears to carry this model.
My secondary question is why I'm asking the first, really. While it's overall performance has been superb, I'm curious if it's upgradable. The OS version built into it is rather laggy and not very pretty to look at... but I understand upgrading firmware willy-nilly is likely to brick, so I don't want to do it unless I know for sure what I'm upgrading.
Any help would be appreciated.
Old 31st Aug 2007, 7:45 pm
DrakkenZero , nobody can be sure which firmware would work 100% with your player. Your player previously may have been manufactured by various factories. They may all look the same on the outside, but likely to be different on the inside (hardware/firmware).
Since your player has worked faithfully for you the past 1 year, i think it should be able to work this way for quite sometime down. So if i'm in your shoes, i'll leave it as it is. These players are not made for any upgrades or updates.
Need Help Identifying a Player Pgeiger General Discussion 0 26th Nov 2009 8:45 am
Need help identifying my player.... intuxik8ed General Discussion 4 5th May 2009 1:19 am
Help Identifying This MP4 Player bjblackmore Support and How To 9 2nd May 2009 7:23 pm
Help identifying my new player m4dbra1n Support and How To 1 2nd May 2009 6:53 pm
Identifying my player Dr.Fix General Discussion 2 17th Sep 2007 8:56 pm
