Glacier sound quality
Old 5th Jan 2008, 4:24 pm
Default Glacier sound quality
I recently bought Glacier 4GB and was very disappointed with it's sound quality.
It has constant hiss and cracks. They're almost inaudible if listened with high volume but when listening at low volume you can easily hear it and it sounds very annoying... making it practically impossible to listen to the music with low volumes.
It drives me nuts that in the supposedly quiet parts of music/movie there's this constant noise.
I have tried with several different earphones.
Is it the same with all the Glaciers or should I ask for a replacement?
Do you hear constant noise with low volume (<10) ?
Old 6th Jan 2008, 1:17 pm
The Glacier uses an older Actions chipset, which has this background noise. It's caused by the LCD backlight, configuring it to turn off after a while (if it's the standard Actions menu you can do it in Settings -> DarkMode) will minimize this background noise when listening to music.
For movies there's not much to do unfortunately.
You may try putting the player in the freezer for a couple days (seriously, but put a piece of paper under it as the metal will stick to the freezer!) and then letting it return to room temperature very slowly before using it again (wrap it in a blanket and put it in the coldest corner of your house).
It may seem crazy, but people have reported much less background noise and better sound quality after doing this. On my old Actions player the sound quality wasn't significantly better, but all that annoying background noise, "hiss and cracks" was gone. This method has been discussed a lot in the MyMPxPlayer.org forum, and none of those which said it's impossible for it to work came up with any proof. :P
It's your call if you try "Operation Big Freeze" or just live with the noise.
PS. This won't void your warranty.
Old 7th Jan 2008, 7:49 am
Default Re: Glacier sound quality
It may sounds strange to you but can you please tell me what is glacier as i dont know anything about that please tell me about that.
Please visit my blog on
MP4 player download
Old 7th Jan 2008, 8:40 am
devilsmaster , the "Glacier" is just a model name frequently used by uxcell as a sort of model branding. Internally it is the same as many other "MP4" players.
Old 7th Jan 2008, 6:27 pm
Thank you, Th3_uN1Qu3, for your answers
I think I will try the "Operation Big Freeze" someday... eventhough it sounds pretty crazy
Old 23rd Jan 2008, 4:12 pm
Freezin it didn't have an effect at all.
The noise is still there, as strong as ever. Piece of crap.
Old 25th Jan 2008, 7:23 pm
That's the risk involved when buying this kind of players. I'm sorry to hear that, maybe you should just ditch it and get a better one.
Honestly what do you think of Chi-Pod & sound quality? abombaci General Discussion 5 15th Jun 2009 5:58 am
Another ay of Improving sound Quality w/o Freezing? theillusionist Mods and Themes 4 27th May 2009 9:28 am
VERY bad sound quality kidcasino Support and How To 3 1st Feb 2009 6:48 pm
Poor sound quality Filipe Support and How To 1 10th Nov 2007 2:47 pm
Can we adjust the sound quality of AMV files? hongkie3 General Discussion 2 19th Jul 2006 2:20 am
