MP4 player suggestion and question
Old 26th Mar 2006, 12:14 am
Default MP4 player suggestion and question
hay im new here...
i whant to buy an mp4player but i whant one with an adapter input so i can charge it not only at my home at the usb port
can u tell if that one have an adapter input?: "http://www.ergotech.com.tw/ergotech/english/productDetail.asp?guid={C67607B2-410E-462D-946F-903401D9F9A8}"
or this one "http://www.p1000.co.il/hot_sale_product/z_31143.jpg"
or this "http://www.p1000.co.il/hot_sale_product/z_31904.jpg"
and if u can give me all the info u got on this tree player's
not only if thay have an adapter input so i well know what should i buy...
THX
(Lol sorry for my bad english)
Old 26th Mar 2006, 12:39 am
Default Re: Help PLz
And yes i forgat, can i buy that battriey that thay have in the Mp4 in the shop? cus the battriey getting older in time and working much less hours
8)
(sorry again for my english :lol: )
Old 26th Mar 2006, 12:48 am
Default Wall charger for MP3/MP4 players
Hi,
I speak from experience as I have the "65K OLED MP3 Player / ET-UC06" from the first link you sent me as well as the "http://www.p1000.co.il/hot_sale_product/z_31143.jpg". Both come with wall charger and USB charger.
I don't know about the "http://www.p1000.co.il/hot_sale_product/z_31904.jpg" as I don't have this player.
However, of all the 10+ different type of mp3/mp4 players I have, ALL of them come with wall charger and USB charger.
If you are unsure, it's best to check it from the person who you are buying it from to confirm it comes with a wall charger. Also check to make sure that the adaptor fits your country's wall plug too as it might have the Chinese wall plugs and not fit for everyone.
I don't know about the Mp4 batteries as all the MP4 players I have always have rechargable batteries. I guess if you want to, you can try taking the case out and replacing the battery yourself. As long as you charge the battery correct and drain it down completely before charging and don't do 'little' charges all the time, the battery should last you awhile.
Hope that helps.
Old 26th Mar 2006, 1:29 am
Thx alot for the help :mrgreen:
one more thing, can u give me a littile tip? what u would buy if u ware me the "65K OLED MP3 Player / ET-UC06" or the powerdisk "http://www.p1000.co.il/hot_sale_product/z_31143.jpg"
and do thay both read Amv?
and what about the quilety of the video and audio? and things like that
and i downloaded the Amv convertor just to see how does it work and when i convertet some of the videos by the instrac' in this fourm, so when i played it in the computer amv player thay jumpet so i downloaded some of the videos in the "downloads" and thay jumpet too, so the "q" is do thay going to jump like that on the mp4player too?
Old 26th Mar 2006, 8:25 pm
Well, both models will probably use the same solution board, so their features and operation would be very similar. I guess it's up to you which on you like the look of more I guess.
Video quality is ok. it's not the best because it's only on a 1.5" or 1.8" LCD screen. Also, you have to convert it to an .AMV file as well, so you will loose quality over the original.
I haven't noticed the .AMV videos we have on our download section 'jumping' though. But it might just be me getting used to seeing it too much? It plays fine on the MP3/MP4 player though. But once again, remember it's not a divx movie and the screen is a lot smaller, so don't expect DVD quality playback on it though. If you wanted something much better, you will probably go with a portable media player (PMP) with a much bigger screen size and with DivX and Xvid playback too.
Hope that helps.
Firmware suggestion PerpetualOmega General Discussion 1 6th Sep 2009 10:10 am
Suggestion for good noname mp4 player? ikesmasher General Discussion 2 17th Apr 2009 3:20 am
Question on MP4 player Hoppes General Discussion 7 5th Oct 2006 6:20 pm
SUGGESTION | always include board & player info w/ firmw doon General Discussion 1 7th Jul 2006 6:24 pm
Suggestion: Battery Icon fizzle05 Mods and Themes 22 13th Jun 2006 11:51 am
