Headphones with 2.5 mm sub-mini jack
Old 2nd May 2006, 7:38 am
Sciamano
Guest
Posts: n/a
Default Headphones with 2.5 mm sub-mini jack
Anyone knows where to buy a GOOD pair of headphones with a 2.5 mm sub-mini jack that fit that damn 2.5 mm sub-mini plug that many MP4 players are equipped with? :?:
Old 2nd May 2006, 9:28 am
[quote="Guest";p="646"]
Originally Posted by Guest";p=&quot View Post
646"]
hi ive the same problem
1 look on ebay for good earphones that are 2.5
2 look on ebay or buy from a shop a earphone jack 2.5 to 3.5 then u can put normal earphones in good luck
:lol: m.coote 8)
Old 2nd May 2006, 9:36 am
Sciamano
Guest
Posts: n/a
Default Re: Headphones with 2.5 mm sub-mini jack
Yeah, I've found some on eBay but don't look very good to me.
They only cost £1, which means they must be REAL cheap...
I'd rather not buy an adapter. It wastes a lot of space, and that would be in contrast to my wanting a small player!
Old 2nd May 2006, 1:41 pm
crazydog
Guest
Posts: n/a
or if u want an adapter.... there are in sotres like bestbuy or maby walmart... adaptors for ipod nano.. i think u can use them 2.. and they only cost like 5 CAD
Old 16th May 2006, 4:04 pm
Guest
Posts: n/a
I bought some on Ebay that look identical to ipod headphones, they work great too.
Old 22nd May 2006, 12:11 pm
you should look for a cable adapter (or however you call that thing with a short piece of cable between the two ends of the adapter.. this way you save space => still fits in your pocket)
Old 23rd May 2006, 6:28 am
Thanks for the hint EgoTrippin! I'll go check if I can find that!
In the meanwhile I've bought a pair of Sagem (an european cell phones maker) headphones with 2.5" jack which work very well.
Old 28th May 2006, 3:01 pm
dimndlady2000@hotmail.com
Guest
Posts: n/a
I found one in the wireless phone section of walmart and it works perfect.
[/quote]
Old 29th May 2006, 5:48 pm
Mobil phone stores sell them for their MP3 playing phones.
Old 30th May 2006, 8:32 am
I just got my 1.8” mp4 player and it has these mini jack headphones. The earbuds aren’t the greatest and my FM transmitter for the car will not fit so I think I’ll cut the earbud cable and solder on a female standard jack to make and adaptor. I just can’t decide if I want a single jack or build a cable with 2 output jacks like a Y splitter or find one of those extension cables with an external volume control to build an adaptor with.
>> output for headphones (jack) << MufaSSa General Discussion 2 12th Nov 2008 7:32 am
Best sounding in-ear headphones I've used. Buzzygirl General Discussion 0 28th Sep 2007 10:57 am
Headphones arucart Support and How To 14 22nd Aug 2007 7:29 am
mini mini review of the FMP pmilladcs General Discussion 5 9th Mar 2007 12:01 pm
Headphones! nidebaba General Discussion 3 20th Feb 2007 7:26 am
