jpg images
Old 19th May 2006, 2:48 am
ntmselvi
Guest
Posts: n/a
Default jpg images
I have copied a few jpg successfully to my player. When i connect the player to my system, im able to view them present.
But when i use my player and go to the view jpg menu, the player restarts !!!! any solution?
Old 19th May 2006, 2:52 am
Default Re: jpg images
ntmselvi
Can you try downloading the sample .jpg, .gif and .bmp files we have on our site? Load them onto your player and see if you can play them.....
Let me know what the result is.
Old 19th May 2006, 8:49 am
ntmselvi,
What is player capacity?
How much of it is used?
Did you buy it on ebay?
Try switching it off/ on.
Finally, what resolution pic did you put on there? E.G. 128x128, etc.
Old 19th May 2006, 3:10 pm
I have the same problem, I did this to fix it
Delete all the images using your pc (DO NOT FORYOUR PLAYER) then unplug it and try opening the pictures section on it from the menu, it will say there is no files, now put some pictures in your player and they will work, that worked for me, may be for you it will .
Changing my Firmware images?. Pocket_Nano General Discussion 4 27th Sep 2006 7:48 pm
70X55 Images jez Mods and Themes 0 4th Sep 2006 6:11 am
Extracting All Images At Once Weecho Mods and Themes 2 14th Jul 2006 6:36 am
playing .MTV, garbled images ljlayos Video related 2 11th Jul 2006 1:30 am
number of images? maaalin Mods and Themes 6 21st Apr 2006 2:29 am
