[solved] Level Meter Visualization!
Old 19th May 2006, 9:48 pm
Default [solved] Level Meter Visualization!
I have a 2 gb Ipod nano clone by "wesproindia". I have a doubt regarding the level meter vizulization shown while the music (mp3) is being played. Is it realtime, i mean does it actually move with the music or is it just for show?
thanks
Old 20th May 2006, 2:07 am
aflatoon
Do u mean the "progress bar" telling you how far along the song has gone or do you mean the EQ bar that goes up and down?
If you mean the EQ bar, then that's not real time, it's just an animation of about 4 different .bmp images.
Old 20th May 2006, 10:03 am
yes i think u r right, its just an animation playing with the song...
thanks!
Old 20th May 2006, 1:34 pm
Default Re: [solved] Level Meter Visualization!
Glad to help and thanks for letting me know's sorted.
low level format on mp3 Lexius Support and How To 1 3rd Jul 2009 1:09 am
brightness level sylar_jones Support and How To 3 19th Aug 2007 11:16 am
sound jumping during the visualization goga2005 Support and How To 2 12th Nov 2006 6:07 pm
Battery Meter poddie Support and How To 5 26th Sep 2006 6:28 am
Battery Level gman34 Support and How To 2 27th May 2006 2:36 pm
