Re: Headphones Question :)
what is this 2 or 3 rings stuff... you mean rings in the stake which is inserted in the hole (2.5 or 3.5)?
If it is so... that makes the difference between stereo and mono adapters. Am I right? |
Some brands of cell phone have that third conductor on there to do various things like allow a mic. By inserting the incorrect one You are basically not lining up the metal bits correctly and won't get the same output you'd expect. |
Take a look at these I have owned these for about two years
The cord is really long enough for your needs, however the site is based in the UK http://www.maplin.co.uk/module.aspx?...&doy=22m7#spec |
| All times are GMT -7. The time now is 9:16 pm. |
