Help identify my player
Old 6th Jun 2006, 9:27 am
Default Help identify my player
I got a player on e-bay. There is allredy a picture of it in gallery.
http://www.mympxplayer.com/album_showpage.php?pic_id=49
I'm searching for FW-Update but i can't identyfi the model name to find the proper FW.
I have problems with some function. I can't select a folder to play, it always start play in root. In main menu it do not browse the functions consecutively. It do not show the battery status. (all these functon are describet in manual)
Thanx
Old 6th Jun 2006, 5:18 pm
plumplum, regarding folders, make sure you have repeat set to normal, and press the play button to select the folder you want not the menu button.
Do not try to update the firmware unless you are 100% sure that the firmware you are updating to is compatible with your player. A player with non consecutive menus and no battery status is better than a player that does not work at all.
Old 7th Jun 2006, 1:07 am
plumbum, "r0m4n" has just uploaded the firmware from his player which appears to be the same as yours. You should send him a Personal Message regarding some of the problems you are having he may be able to help.
Old 7th Jun 2006, 5:27 am
Guest
Posts: n/a
Default Re: Help identify my player
You are right, the menu and battery status are onli peanuts, it onli indicates for me that there is a real problem. To select a directory does not work at all and that's something a 2GB player realy needs.
I would be absolutly satisfied with this player without this buck. it has nice and robust metal enclosure, the buttons could be better/nicer but they work properly. Nice big display. it has lot of features even the radio works well. no need of software on all systems (i use windows, mac and linux). At last 2GB capacity for about 80€ is a strong argument against iPod.
of course I don't wont to 'kill' my player. I will try the dump from r0m4n that should be safe.
Thanx for any suggestions.
Old 23rd Jun 2006, 5:13 am
The problem with selecting music from a particular folder is common to most MP4 players. Basically it doesn't matter what folder it is in, the player will play all your MP3,WMA etc from all your folders.
You can arrange the files in a playlist type of way, so they play in the order you want.
This is my experience with MP4 players, do newer firmware versions allow music to be played from one particular folder and not play all of the music on the player?
:lol:
Old 23rd Jun 2006, 7:07 am
razzer001, Depends on your Repeat settings
NORMAL will play all music files in sequence until the end.
REPEAT ONE will repeat a single song
FOLDER will play the files in a folder
FOLDER REPEAT will repeat all music files in a folder
REPEAT ALL will repeat all files in a loop
Old 23rd Jun 2006, 7:25 am
haha, thanks, your right, i feel stupid for not seeing that ops:
:lol:
Old 13th Jul 2006, 9:56 am
Mark
Guest
Posts: n/a
Hi, I set every type of repeat mode but i cannot select the folder. my firmware version is: pma300_006 - 2005/11/04 ryj-3.5.35 2005/12/16.
I had 24 album/folder on my ipod clone but i cant play them because i need 5 minute to play some albums. I try all your methods but don't work. I format fat 32 and fat thinking is a problem of file system but nothing. please help me. is there a firmware compatible with my mp3player that allow me to set folder to play?
Old 13th Jul 2006, 4:11 pm
Mark, I have version pma300_700 with repeat set to normal I can browse to the desired folder and press the play button to load that folder.
Old 14th Jul 2006, 12:01 am
Mark
Guest
Posts: n/a
have you upload pma300_700 version here? do you think i can use it?
Please help me to identify my player GrandAgent Support and How To 13 27th May 2009 1:04 am
Help, identify my MP4 player paulpacs General Discussion 2 1st Mar 2009 3:45 am
Identify an MP4 Player ChtiClem Support and How To 1 3rd Nov 2008 7:39 am
How do I identify a player. Everso General Discussion 7 1st Nov 2008 1:28 pm
Please help me to identify my mp4 player! xemtin Support and How To 1 17th Mar 2007 5:24 pm
