[Solved]Info needed
Old 13th Jun 2006, 1:22 am
Default [Solved]Info needed
Hi all
Recently I bought this MP4 player (obviously china make) it is 1GB
The firmware version is
2005/12/16
3.5.35
2006/03/22
JTYMD038V4
Can anyone confirm me is it really 1GB or a fake one.
How can I check that?
regards
prasanna
Old 13th Jun 2006, 1:26 am
prasanna, this does not seem to be a problem with to many 1GB players. The best way to find out for sure is to open the player and note the brand and serial number of your memory chip (usually the largest chip on the board). Then doing a Google search with this information will find the specifications for your chip.
Old 13th Jun 2006, 1:32 am
Default Re: Info needed
tadad1
Thanx for ur reply.
Opening the player and checking will do that.
I asked this question as i got scared from reading some posts on fake memory.
Buy seller had given a statement that "dont format the player otherwise it will play only first 25 songs and will restart".
Is this have to do something with fake memory since 25 songs will approximately come to 128mb.
Bear with me as I ask too many questions
prasanna
Old 13th Jun 2006, 1:35 am
prasanna, ok if your seller has told you not to format your player I would definatly be checking the chip to find it's real capacity.
And feel free to ask as many questions as you need, that is why the forum is here.
Old 13th Jun 2006, 1:56 am
hi tadad1
I tried to open the case but stopped fearing i would damage it.
Is there anyother way?
If it is a fake one it will not play files beyond its original memory capacity right?
Right now I have 990 MB of songs in my player.
prasanna
Old 13th Jun 2006, 2:23 am
prasanna, you could try loading it until it is full and then start playing. If you start having problems then this could mean that something is not right with your chip.
The other thing you could do is without actually running the format process, right click on your player in explorer and select format and see if it will let you select FAT if it will only let you select FAT32 this could also mean there is a problem.
Ultimately the only way to be sure is to look at the chip.
Old 13th Jun 2006, 2:32 am
Hi tadad1
I loaded the player to its full capacity and played the last song which was of duration 5:03 mins it played fully without any problem.
I also checked the format option, it is allowing me to select all the three FAT,FAT32 and NTFS.
Anyhow I will try to check the chip.
Thanks for ur replies
regards
prasanna
Old 13th Jun 2006, 2:58 am
prasanna, sounds like you could be ok, i hope so.
Old 13th Jun 2006, 3:22 am
prasanna
Cool.
Maybe FAT32 is ok in the end? Or maybe it's ok for the NEWER Mpx players instead?
It's always recommended to me (and in some manuals) to use FAT so I never really tried FAT32 instead.........
Please help me getting some info about my MP4-player! Gore Support and How To 7 22nd Jan 2009 11:09 am
Info on this MP4/PMP Player jaysinn General Discussion 1 28th Dec 2008 10:39 am
AK1025 Firmware Needed!!! [color=red] [SOLVED][/color] jojorov Dead Players 4 26th Mar 2008 3:35 am
[solved] help needed to play video files. psmith0103 Video related 34 20th Dec 2006 8:04 pm
more info on this player? backudog Support and How To 8 2nd Nov 2006 10:08 pm
