-   -   MP4 1.5" 1Gb ITALIAN Correct Language Firmware... (http://mympx.org/forum/general-discussion/33299-mp4-1-5-1gb-italian-correct-language-firmware.html)
fakiro 14th Jun 2006 4:20 pm
I've correct the firmware of my mp4 1.5" 1Gb player because have bad Italian menu language, most probably electronic-translation...
The info firmware are:
2005/12/16
3.5.35
2006/03/31
KTT 688_V4
...plus mod "ipod's" start-end images...
...see in download section...
admin 16th Jun 2006 1:10 am
fakiro
Thanks for listing your firmware on the site.
You can also upload it DIRECTLY to this site if you want to? Please do that so that we can give you credit for it.
anto 21st Jun 2006 6:39 am
Re: MP4 1.5" 1Gb ITALIAN Correct Language Firmware...
How is it possible to backup & restore the firmware?
I received no software with the MP4 Player?
I'm olso having problems with IDtags? Some song is correctly displays the TAGS meanwhile others print strage characters...
My firmware version is:
PMA300_006
2005/11/04
RYJ-3.5.35
2005/12/16
admin 25th Jun 2006 2:25 am
anto
Can you create a NEW post for your message please? Put it in the "Support/How To" section. You will get better responses that way.
andrears250 3rd Jul 2006 8:04 am
fakiro la tua versione non funziona
(fakiro your version doesn't work)
