Interesting info on rechargeable batteries
Old 3rd Jul 2006, 9:11 am
GeorgeIV
Guest
Posts: n/a
Default Interesting info on rechargeable batteries
Seeing how many people ask how to charge their batteries, i'd would like to share with you these links...
http://www.batteryuniversity.com/parttwo-34.htm
http://en.wikipedia.org/wiki/Lithium_ion_battery
I hope they help you.
And for the lazy ones that don't like to read, here's something taken from the links:
"Avoid frequent full discharges because this puts additional strain on the battery. Several partial discharges with frequent recharges are better for lithium-ion than one deep one. Recharging a partially charged lithium-ion does not cause harm because there is no memory. (In this respect, lithium-ion differs from nickel-based batteries.)"
"Unlike NiCad batteries or NiMH batteries, lithium-ion batteries should be charged early and often. However, if they are not used for a longer time, they should be brought to a charge level of around 40%."
Old 3rd Jul 2006, 10:34 am
Thanks, good tips! Didn't know that.
greets
Old 3rd Jul 2006, 2:25 pm
Great! ;D
Tnx for the tips! ^^
Old 3rd Jul 2006, 2:37 pm
I thank you as well... Hopefully this will preserve the life of my battery...
..::Weecho::..
Old 6th Jul 2006, 10:05 am
Default Re: Interesting info on rechargeable batteries
thankx
Old 8th Jul 2006, 1:57 am
So most chiPods using what type of battery chemistry?
Old 8th Jul 2006, 10:02 am
Georgeiv
Guest
Posts: n/a
Those wih internal batteries use Li-ion
and those with external... dunno I guess you can use either simple alkaline batteries or ni-mh 1.2v... i'm just guessing... I have one with internal battery
Technika mp-507. 4GB (not hacked) interesting glitch confused.brit Support and How To 1 10th Jun 2008 2:25 am
Apple iPod Batteries MojoPiN Support and How To 6 3rd Apr 2007 3:15 am
Where can I buy Mp3/4 Batteries itspete Support and How To 7 2nd Mar 2007 4:48 pm
Are batteries replaceable in Nano clones? michiganjfrog General Discussion 3 13th Dec 2006 11:37 am
what batteries fit in Super I-Platinum 1.8inch 2GB silent-type General Discussion 2 12th Dec 2006 11:14 am
