Advice: compression on mp4/mp3 player
Old 5th Jul 2006, 5:33 pm
Default Advice: compression on mp4/mp3 player
need advice whether its safe to compress my mp4/mp3 player. btw i only have windows 98se.
Old 5th Jul 2006, 6:33 pm
ljlayos, Never heard of anyone trying it so can't tell you one way or another. My only concern would be that the firmware may not be able to read from a compressed drive which could cause you problems.
Old 6th Jul 2006, 12:14 am
ljlayos
If you want to save disk space, try converting your files to .WMA files instead of MP3 as it will be smaller so saving you space.
Compression is slower for Windows to access, I don't know what it will be like on your player (or whether it will work for all that matter).
Old 10th Jul 2006, 7:59 pm
thnx appreciate the advice
Some advice on this player hora123 General Discussion 13 23rd Dec 2007 11:20 pm
Need some advice for my next player. kope007 General Discussion 15 25th Jul 2007 3:23 am
Better Compression black_sheep Support and How To 2 17th Sep 2006 5:34 pm
advice on getting an mp4 player General Discussion 2 19th Jul 2006 4:27 am
wat amv players are and wat kinda compression and how small klkc2 General Discussion 5 11th May 2006 6:29 am
