firmware
im postimng here buit i dont know if its getting posted or not but my ? is how do u download the 3.5.37 firmware then reinstall it ive lost some of my folders out of my fake nano and need to reinstall the firmware can some one reply to me and give some help im a neebie at this stuff
do you know which firmware your player has?
3.5.37 the new one that was posted
budi_holi
Reloading the firmware won't put the folders back on your player. Are you having problems with your player? If so, can you explain to us what the problem is and whether you've done anything before the problems started happening (ie: try to update the firmware). |
ya when i got it it had a mp4 folder and u could put files in it
it dissapeared and is no longer there now u cant scan thru the music maybe 2 or 3 songs thgen it freezes up |
budi_holi, Is your player working otherwise, can you still turn it on and off, see the menu's etc?
Have you unplugged it wthout a safe removal? If you can see it in explorer right click on it and select Properties>Tools and do an Error Check with both options. Then format the player by right clicking and selecting format. Then make a new folder and try some new music. |
ya other then that it still works and turns on and off i have to go to my computer and bring up removible drive s to get it up
i make a folder and put music in it and drag it to the drive but it dont show up no where eeven tho its showing in the screen when i bring it up
budi_holi, Copy and paste the folder, dragging and dropping may only be creating a shortcut.
| All times are GMT -7. The time now is 9:08 am. |
