hacked "4, 8Gb" player
  #31 (permalink)
Old 7th Aug 2006, 7:10 pm
Guest
Posts: n/a
Originally Posted by Guest";p=&quot View Post
lcdguard - No longer registered with eBay
Looks like the con-man has done a runner before more people complain.
Bit like when he/she had an account called kcshophk
I wonder what the next account will be opened as? :x
He is selling under the ebay name bestmp4 now!.
  #32 (permalink)
Old 8th Aug 2006, 3:34 am
Que Que is offline
How did you find out? What is the link between lcdguard and bestmp4?
  #33 (permalink)
Old 8th Aug 2006, 9:06 pm
Default Re: hacked "4, 8Gb" player
Bravo!!!, Good on you mates !!! May I say, thank you all;
For verifying what I initally found in doing a 'lil research before buying my first nanoclone from China (ebay) in May 06.
It seems my initial hypothesis was correct, and that there are many sellers who have hacked 'Chipods' ( but probably don't know it).
I mean that the sellers don't know as much as we all all know, which is that the manufacturer has duped them into thinking they are selling an 8 Gig or 4 Gig player. Most sellers have no clue that 2GB is the max currently available in a flash player. Please, please do NOT buy 4, or 8 Gig players as they do NOT exist!!!!
Please read my original post, and if necessary send a copy of it to your seller.
Maybe he will forward it on to his supplier, and if enough of us do this, all of this madness will stop!!!!! CAVEAT EMPTOR! (buyer beware).
Good luck all.....
Iridium
  #34 (permalink)
Old 9th Aug 2006, 9:59 am
OKI
Which formating tool should I use if I have a coned mp4 player ????
it says 4 gb when I use windows soo...
and the software that came whit it(downloaded as well) wont format it ??
lekie
  #35 (permalink)
Old 4th Sep 2006, 10:09 am
:lol: [color=#][/color]I have found that corruption can occur through the sync function of Windows Media Player. The MP3 player has a limit in the number of files in folders and the number of folders. I found a lot of MP3s were corrupt after doing a sync operation. These MP3s had played fine before on the MP3 player. I could not delete the corrupt files. The player had to be reformated.
I can only format my Wilson Nano clone with Windows Me for some reason I am not sure of. It could be Windows XP will not allow less than fat32.
I am able to format and able the check the device as a disk using Windows Me full format and it gives me 3.99 gb useable space.
I have created folders in the root directory of the Mp3 player for Video, Artist, Oldies, etc. In these folders are subfolders. For example under Artist I have a serperate folder for each artist. I then transfer each album of that artist to theArtist's folder. I rip the CD with Windows Media player and use it to update the CD information. This way I get the album art in the folder with song title, genre etc.
When I transfer to the Nano clone, I only use the copy and past method. I copy and paste the whole album folder from Media player to the MP3 player.
In order to see the folders when using the player, I select local folders and keep going back until I see root or the subcatagories of root. I keep making my selections with the M button until I reach the folder with the songs and then use the play key.
I am telling you all this because it is very easy to get format errors with files and that they can be avoided and are not necessarily a memory problem. Sending over 99 songs at a time the the MP3 player is asking for trouble. It does work sometimes.
  #36 (permalink)
Old 4th Sep 2006, 4:39 pm
Guest
Posts: n/a
Originally Posted by dannyboy";p=&quot View Post
:lol:
But have you played all songs? Everybody with a hacked 2gig sold as 4gig can put 4 gig (lill less) on their players, but half won't play, because they are not there, just indexed as being there, that's the hack.
Use the tools on this forum to do a real format, you will end up with 2 gig.
As long as stores like uxcell.com do not sell 4 gig nano-clones, there are no 4 gig nano-clones.
  #37 (permalink)
Old 8th Sep 2006, 4:19 am
Originally Posted by markshmid1";p=&quot View Post
I was thinking maybe the reason I am having trouble, Juicing up my gizmo again is because I have (found) two drives. The updater is looking @ the one Meg drive which is the real one but it cannot but the info in there because it is too small.
A good 15 or more years back (when hard drives where really expensive and all we had was a 20GB there was this program called STACKER which doubled your hard drive space.
I do not recall exactly how it worked – but I do remember that: 1) it made a seconded drive read only 2) it slowed the heck out of the computer 3) you would have to defrag all the time, or else you where in risk of crashing or it would work even slower
So my guess this is what they are doing and somehow hiding the second drive (which popped up by me).
This is what I've had written about earlier. The old HD proggies would hide the real cylinder values and would let you to write to the factory reserved sectors of the drive what is reserved for recovery only in case you have a bad sector.This way constantly moves data back and forth but would crash soon as it reaches the logical limit of the given platter.
Similar trick here.Reserve about 1M of protected space and use a spoof to map out the rest of the memoryblocks.
Windows is a stupid operating system it's easy to fool.
It's still operating on the arcane x86 pc architecture what supposed to be dead and buried since the late seventies.
This is just shows the inadequacies of men.
Human nature never likes things to change but it must.
Because of this stupid safezone what ppl need usually, is the very couse of suffering we must endure.
Not just technical but social in nature.
anyhow...I'm off subject already..lol
  #38 (permalink)
Old 8th Sep 2006, 12:49 pm
clamp3
Guest
Posts: n/a
i buy mp4 player 4GB .. real 1GB this is imposible ?
  #39 (permalink)
Old 8th Sep 2006, 1:58 pm
clamp3
Guest
Posts: n/a
my chip is K9K8G08U0A samsung with firmware 3.5.37 thereby arrive . and this is 1 GB????????? ???
  #40 (permalink)
Old 8th Sep 2006, 2:35 pm
Guest
Posts: n/a
Yep, you are scammed. go complain to the seller, demand refund, leave him bad feedback, complain @ paypal if you used it, and @ ebay. The full works!
http://www.google.com/search?lr=&ie=...8&q=K9K8G08U0A
SOLUTION - Fixing "Disk Error" in hacked AK2025 players TonyB Support and How To 36 10th Jun 2010 3:36 pm
eBay seller "supergift468" sells hacked 8GB player dittoLIVE Bad sellers/Blacklist 0 10th Mar 2009 9:54 pm
Links in the "Store" to hacked player listings? Superdad289 General Discussion 14 17th Dec 2007 2:16 am
hacked "8Gb" player Iridium General Discussion 2 8th Jun 2006 9:48 pm
