Nano Clone ipod 1GB -- battery change
Hi everybody!
[align=justify:dd7d9584f1]I think it would be a nice idea to furnish the necessary information by users about the proceedure for changing the built-in rechargeable battery, battery specification, guidelines for extending the battery life etc in this forum for the benefit of myMpxplayer community. I understand from the retailer that the battery change is not possible at end-user level and hence the unit should be returned to the retailer for servicing. Expecting guidance from forum members.[/align:dd7d9584f1] Best regards jasstone |
Re: Nano Clone ipod 1GB -- battery change
The inside of the nano clone I seen had a small battery that had 2 wires coming off of it, and the battery was soldered to the chipboard...so if you can find a replacement...then you can just resolder a new one on...But I havent found any places that sell the battery of that size to replace it?
Hi Rocker81
Thanks for the feedback. |
Would a battery for the Ipod nano fit in?
| All times are GMT -7. The time now is 10:01 pm. |
