firmware upgrade
Old 12th Jul 2006, 4:16 am
torkus
Guest
Posts: n/a
Default firmware upgrade
hi folks!
I hope u can help me.
my Mp4 player has a firmware version of:
PMA300-006
2005/11/04
RYJ-3.5.35
2005/12/16
I wanted to know if its worth upgrading the firmware.
If so, which version?
Old 12th Jul 2006, 11:18 am
Guest
Posts: n/a
Default Re: firmware upgrade
Same question here.
Old 12th Jul 2006, 5:23 pm
torkus
Updating firmware on your player is very risky. I wouldn't recommend it as the hassels involved with recovering a 'dead player' if flashed with an incompatible firmware is a nuisence and time consuming.
In some cases, recovering a dead player from incorrectly flashing your player with an incompatible firmware might render is completely dead instead.
So there is a high risk of that happening. Updating the firmware to a new version won't guarantee you will get new or updated features.
Majority of players are DIFFERENT and majority of firmware is specific to player or MPx manufacturer.
Old 13th Jul 2006, 3:23 am
torkus
Guest
Posts: n/a
Thank you for that info. admin.
I will not now try & update the firmware based on your advice.
Once again
Thanks!
:lol:
How to upgrade the firmware BLACKDRAGON Support and How To 1 14th Jan 2008 12:23 am
Upgrade Firmware MasterMark Support and How To 2 14th Mar 2007 10:07 am
CANNOT UPGRADE FIRMWARE amishjha@gmail.com Support and How To 3 13th Oct 2006 11:15 pm
I want to upgrade my firmware.... hmx Support and How To 1 17th Jul 2006 7:17 am
Firmware upgrade max2 Support and How To 4 8th Jul 2006 4:31 pm
