MP4 questions - First post so bear with me.
Old 13th Jul 2006, 8:29 am
Default MP4 questions - First post so bear with me.
Hi all,
I have been wanting to buy a 4gb mp4 player from ebay for a while now, but kept putting it off as when I was reading feedback there was always 1 negative comment about the memory being 'fake'.
As it happens I was checking the feedback today and somebody had left this websites address in the feedback, and from what I have read so far it looks like I was right to be suspicious about the 4gb.
Anyway, What I am after is a cheap 2gb mp3/mp4 player just to get me started. Are the nano style ones on ebay my best bet? If anybody has bought one from there could they let me know the sellers name so I can buy in confidence please, or a web address of a good seller that ships to the UK?
Sorry if this is in the wrong place.
Old 13th Jul 2006, 8:38 am
Hi goldenballs,
Not so sure about buy with confidence if you decide to go the HK route like I did - I ordered two and both came in just over a week for a good price. But ordering from China carries it risks, i.e problematic in sorting if the item doesnt turn up, and possible hold-up at customs. ( You are legally supposed to pay import duty and vat ), but most are sent marked as "gift", and I received mine with no charges or hassles.
DIYSHOP3 ( Check him out - he was doing 2GB ones yesterday, but only see 1GB ones today )
Hope that helps a little
Cheers
Si
chipod 1GB 1.5" Screen , Black with matt black silicon cover
Old 14th Jul 2006, 2:14 am
Default Re: MP4 questions - First post so bear with me.
I purchased a 1.8 " 2gb, Ipod clone from e-bay. Under £50. The instructions are rubbish but the player is pretty good for the money. Already playing vids and music, although vid quality is pretty poor.(will have to work on that)
The seller was :-http://stores.ebay.co.uk/WINSOR-DIRECT
Hope its okay to post a link.
They are based in the UK, so if there are any problems you can find them and give someone a slap. :evil:
Old 14th Jul 2006, 4:28 am
goldenballs
It's good you did some reading up before buying the 4 GB player and also it's good that you have read their feedback too.
A few people now have mentioned they have been stung with 'hacked' players.
Sorry, Im not from the UK so can't give you the exact details of eBay in the UK.
Safest bet is to go with 2 GB player, not 4 GB. Maybe post a comment/question on the auction saying if you discover that the player has WRONG size storage, will they do a refund or exchange. That way you are covered alittle more as you have made the effect to mention it.
Also, another suggestion is when you do decide to get it, FORMAT it straight away! Then fill it up to the max and try playing all songs. This will tell you immediately whether it's a geniune player or a hacked one.
Good luck.
Old 1st Aug 2006, 1:20 pm
geo_star_1
Guest
Posts: n/a
Ive bought 2 off platinumteam01 look at this page theres lots 2 choose from ebay
there realy cheap and weve had no problems
Old 8th Aug 2006, 6:20 pm
Guest
Posts: n/a
What size you get it from him? He's selling 4GB one also, anyone use it, is it hacked??
Old 8th Aug 2006, 9:20 pm
Random Task
Guest
Posts: n/a
OK, lets be perfectly clear :
1,948,198,461,414,614,6146 Gb = GUARANTEED HACKED.
12 Gb = GUARANTEED HACKED.
10 Gb = GUARANTEED HACKED.
8 Gb = GUARANTEED HACKED.
4 Gb = GUARANTEED HACKED.
2GB= probably OK.... Follow instructions on how to check it our on this site....
Iridium
Bad first post Rainier_Tom Dead Players 5 4th Jun 2009 12:46 am
2nd post. this has many topics rontopia General Discussion 5 26th Jul 2008 8:23 pm
Is there a whitelist post? Husker Bad sellers/Blacklist 7 29th Jan 2008 9:30 am
how can i post a new theme i made? ozzy8031 Support and How To 1 30th Sep 2007 8:20 pm
I cant post to forums jdray Support and How To 1 11th Mar 2007 9:05 pm
