Help me find a skin!!
Old 14th Jul 2006, 10:33 am
PiMP
Guest
Posts: n/a
Default Help me find a skin!!
Ok.... my iPod nano clone (1gb 1.5" colour) is: 40mm x 78mm x 12mm.
It has an inbuilt speaker, and headphone socket at the base (at the right). Here is the pic:
At the moment, all i can find on eBay are skins that fit wider, longer and slimmer players none are the same size as my player!! Do you have any suggestions?
Old 22nd Jul 2006, 2:59 pm
PiMP
Guest
Posts: n/a
Default Re: Help me find a skin!!
wow thanks for all the help guys :roll:
Old 22nd Jul 2006, 3:24 pm
Hey There "PiMP", well im sorry no one has replied to your message as yet, but I have only seen 2 type sof cases available. One type has the opening for the headphone on the side and the small USB on the bottom and another which is designed for 1.8" mp4 players with the USB on the side and the headphone jack on the bottom. Unfortunately, I do not think a case for your player exists, mainly because of the built-in speaker you have. Can anyone else help PiMp out with his problem?
[size=12]Enkay Blog - Comprehensive Blog that talks about Technology, Web Reviews, Car Reviews, Interesting Financials & Videos from across the web!
Old 22nd Jul 2006, 3:53 pm
PiMP
Guest
Posts: n/a
Thank you for the heads-up bsaylors
Old 22nd Jul 2006, 6:26 pm
PiMP, You could try finding a mobile phone case that fits your player, You may have to add holes for earphones etc in the right places but some of the smaller compact cases fit quite neatly.
Old 23rd Jul 2006, 4:25 am
PiMP
Guest
Posts: n/a
tried that, and no success
was thinking, can i buy a LCD screen protector and cut it to fit the player?
Old 23rd Jul 2006, 6:39 am
Yeah, you can most certainly do that. Personally I bought the PDA screen protectors (some at the dollar store - you get 12 in a pack) and resize them to fit the player, works like a charm!
Old 29th Jul 2006, 2:26 pm
Hi all. I have a very simular player (small usb in bottom, headphone jack bottom righthand side). I lack a speaker. Could I ask where you found the 2 you mentioned eariler? I was at a flea market today, and all the cases/skins fit, but they cut off about a 1/5 of the screen and controls.
TIA
Old 1st Aug 2006, 10:37 am
Well PIMP i can tell you that cases for your type of player are out there, i sell the same player, except it doesn't have speakers and i bundle them with a silicon case.
I am sure you could get the same case and alter it yourself for the speaker.
I can't help you get one as i don't sell them individually, but i am sure there is probably a seller on either ebay usa or ebay.co.uk that does sell it, look for sellers that sell 'baby nano', 'mini nano' or something on those lines, thats usually the name for the type of player you have.
Hope that helps.
:lol:
i want to mod the skin in my mp4 basarium Mods and Themes 6 27th Apr 2008 7:22 pm
New Skin for Onda vx858 Seraph Mods and Themes 9 28th Mar 2008 10:31 pm
skin my mpx interface sniperwolfje Mods and Themes 1 3rd Aug 2007 7:46 pm
Ipod skin help daryoush111 Mods and Themes 4 25th Dec 2006 4:26 am
Where can i find directions to re-skin my player? dansvob Mods and Themes 1 19th Jul 2006 7:32 pm
