identify my mp4 player
Old 16th Jul 2006, 7:10 am
fenoamby
Guest
Posts: n/a
Default identify my mp4 player
I want to upgrade my firmware 3.5.35 to 3.5.37.
I have save my actual fw but when i upgrade myscreen become blue but nothing happend.
i modified the brightness of the new firmware but it s always the same problem.
Can i have some help? I open the player but the display is glue on the chipset.
My player :
http://<a href="http://img19.imagesh...mp44cm.jpg</a>
Thank You
Old 16th Jul 2006, 7:30 am
fenoamby, The firmware you are upgrading to is not right for your player. It is impossible to tell you what firmware you need by looking at your player. The chances of you upgrading to 3.5.37 are very slim, you may also kill your player so be very careful. Also upgrading to 3.5.37 will give you no new features it will most likely be exactly the same as what you currently have.
Old 17th Jul 2006, 7:07 am
Guest
Posts: n/a
Default Re: identify my mp4 player
I open my mp4 player, and i solve the problem of the display on the chipsets.
I found 3 chipset :
1/ ATJ 2085
F3079AB53K
2/ SP3767hn
06CS04
3/ SAMSUNG 619
K9K8C08U0A
PCB 0
I'm watching everywhere on the green card but i only found : Rev 3 write on it. No id number.
I'll post a screen of my mp4 open.
Thank you for your help.
Old 18th Jul 2006, 7:18 am
fenoamby
Guest
Posts: n/a
This is the screen of my mp4 open if it can help someone.
http://<a href="http://img101.images...440tf2.jpg</a>
Old 20th Jul 2006, 8:42 pm
fenoamby
Guest
Posts: n/a
Nobody can help me ??
Where can i found the board ID or someone have the same ....
Watch my picture and say me please....
Old 20th Jul 2006, 9:43 pm
fenoamby, I have no idea where to find the ID some boards do not even have any. If you have backed up your original firmware you should be able to restore your player with that.
Old 25th Apr 2007, 7:00 pm
i have the same on and for some reason i tryed to update
it but my backup is know good if some one knows where to get the right firmware please let me know
Please help me to identify my player GrandAgent Support and How To 13 27th May 2009 1:04 am
Help, identify my MP4 player paulpacs General Discussion 2 1st Mar 2009 3:45 am
How do I identify a player. Everso General Discussion 7 1st Nov 2008 1:28 pm
Please help me to identify my mp4 player! xemtin Support and How To 1 17th Mar 2007 5:24 pm
Help identify my player plumbum General Discussion 13 14th Jul 2006 5:04 am
