Can we adjust the sound quality of AMV files?
I wonder, the AMV conversion doesn't seem to give options to select the audio quality. Is it possible to get a higher audio quality for AMV conversion?
hongkie3, No audio is hard set at 22k mono in the converter. The new version in the download section 4.03 indicates 88k but still only converts to 22k.
It also depends on the original file, i have never had bad audio if the original file had good audio.
| All times are GMT -7. The time now is 10:31 pm. |
