Battery Charge Problem?
Old 19th Jul 2006, 3:27 am
Guest,
It's strange that you have to leave your player playing though.
It sounds to me that you might hve to check the OFF timer and SLEEP time as what I think is happening could be that your player switches off after a certain time and for some reason, doesn't then charge if it switches off.
Also, when you charge your player, do you use the [on/off] switch to turn it off? You shouldn't need to.
Also, while you left it charging on your computer, was your computer ON? You computer will need to be on to charge the player.
Here's some things to try:
1. Set a time/clock setting in your player.
2. Go into the settings of your player and chance the settings for 'dark', 'darkle', 'sleep' and 'off' time to ZERO instead. This should now disable your player from going to sleep or turning off the screen.
3. Now leave your player charging on your computer. Remember to leave your computer ON as well.
Old 20th Jul 2006, 2:04 am
Guest
Posts: n/a
Default Re: Battery Charge Problem?
when charging, does it matter if the screen is showing the mp3 player screen? this is the only way the screen stays on.
if i just plug the usb in, a picture of the mp4 and pc show up with (zzz's) on it, then the screen goes off, is is normal? Also , how long until its fully charged?
Old 20th Jul 2006, 2:19 am
Guest, it is alright if the screen turns off in fact it is better as the player will charge faster with the screen off. If the MP3 screen is staying on you should go to Settings>LCD Set>Darkle or Black and set the timer for between 5 or 30 seconds then the screen will turn off at the set time conserving the battery. The LCD is proberably the biggest drain on the battery. You may need to set the Power Off setting to 0 as well.
Old 20th Jul 2006, 2:25 am
Guest
Posts: n/a
ok, bit confused now, you say set the lcd timer between 5 or 30 seconds.
but the admin says set it to zero.
Old 20th Jul 2006, 2:41 am
Guest, The LCD off setting of darkle or black sets the screen to turn off after a certain time, every thing will still be working, music playing etc just the screen goes off. This is to conserve power.
The Power off setting sets the player to turn off if it is inactive for a set period of time. So if it is on and you are not playing any music or activating any buttons it will turn off and you have to hold down the play button to start it again.
As long as the the player is on when charging it does not matter if the screen turns off but if it powers off it may not charge.
  #16 (permalink)
Old 20th Jul 2006, 4:52 am
Champenois
Guest
Posts: n/a
tadad1 is exactly right - i am on the chinese mainland, and deal in many different models of mp3 / mp4 players. when you plug your player into your pc or wall power supply, TURN the power switch ON religiously. not doing this causes charging problems with many different models.
  #17 (permalink)
Old 20th Jul 2006, 5:39 am
Guest
Posts: n/a
how long do they take to charge fully from flat? i've been charging mine for 3 hours now, and the battery meter is still going up. but if i un-plug it, it says full battery. so does the battery meter stop going up when fully charged?
  #18 (permalink)
Old 20th Jul 2006, 5:47 am
Guest, It depends on the player I have one that keeps showing the charging animation the whole time it is connected while the others stop when the battery is full. A full charge should take 3 - 4 hours depending on the battery size.
  #19 (permalink)
Old 20th Jul 2006, 5:55 am
Champenois, May I ask what is your experience with 4GB and 8GB players, we see so many posts of people buying them and later finding that the true memory size is much smaller. It appears that they have been manipulated in some way so that they are read as having much more storage capacity than really exists. Have you had any experience with players with this problem?
I have seen a photo posted by a member who's player had a board that had provision for a second memory chip which would allow 2x2GB chips for a true 4GB but have never seen any proof that they exist.
Any comments you can make would be most appreciated.
Thanking you in Advance,
Terry
  #20 (permalink)
Old 23rd Jul 2006, 2:09 pm
Bleachin
Guest
Posts: n/a
Can somebody help me with my charging problems.
I have let the battery run flat on mine, now it will not switch on at all and when I plug in the usb nothing happens. Does anyone know how to get it to charge? Is there any thing else I can do, cant really return the player as it was baught in singapore and I'm in the UK
TIA
Unibit X-320 Player - How do I charge battery? TyphoonTycoon Support and How To 1 24th Nov 2007 8:50 pm
best way to charge battery Aiu Support and How To 3 11th Jan 2007 6:20 pm
18 Hours Continuous Music Play on a Single Battery Charge. tadad1 General Discussion 0 17th Nov 2006 7:40 pm
how do i charge the battery peruvianfreak250 Support and How To 1 18th Sep 2006 5:59 pm
