Battery Charge Problem?
  #21 (permalink)
Old 23rd Jul 2006, 4:22 pm
Bleachin
When you plug it in to the USB the player must be turned on at the switch or it will not charge.
Try another USB port.
If you have a wall charger try that.
If you still have no joy your USB cord may be faulty.
  #22 (permalink)
Old 24th Jul 2006, 2:22 am
Bleachin
Guest
Posts: n/a
Default Re: Battery Charge Problem?
Thanks.
Just tried all of that with no result.
Just Tried the resetting the dead player and didnt get any response from the machine either.
From reading a little more it appears that I may have fallen victim to the batteries and the specifics of charging.
Does anyone know where to buy a replacement li-ion battery for it. All I know is that its 3.7 v everything else is in chinese on it so I cant get any real details.
  #23 (permalink)
Old 24th Jul 2006, 3:05 am
Bleachin
Just to confirm, you've tried another USB cable as well as a wall charger and it's not charging your player?
If that is the case, seems like a faulty battery.
How long have you had your player?
Has it charged ok in the past?
Has anything been done to it prior to this started happening?
  #24 (permalink)
Old 24th Jul 2006, 12:26 pm
Bleachin
Guest
Posts: n/a
Yep tried numerous usb and different computers.
Sadly I have lugged it around SE Asia for 6 weeks with only the demo items on it and with the battery charged as it was. I plugged the USB cable into it while it was on. It showed connected on the screen and appeared to be charging so I left it upon return a few hours later dead.
The most annoying part of it is that I have now looked on E-bay and it looks as though I could have baught it on there for cheaper anyway.
Unless you can think of some other things to try, I'm not holding out much hope.
Thanks for helping though.
  #25 (permalink)
Old 28th Jul 2006, 9:37 pm
Is it possible for the lithium ion battery to die out after charging it a few times
It was working before when I would charge it while the songs continued playing , while it hooked up by usb to my pc
Now it does not seem to be charging :cry: I opened the mp4 player and smushed the battery in again to make suere and now I am charging and thre battery indicator is showing it charging but when I disconnect the usb I do not see a difference in the indicator
I really do not know whats going on, I hope it will charge and if not then how do I get a new battery? :cry: :cry: :cry:
  #26 (permalink)
Old 28th Jul 2006, 10:09 pm
Nikki, I suppose it could if it were faulty but it should have a life of several hundred charges before it dies. I did a google search for 3.7v Lithium Polymer batteries and the only places I found that sell them are Model Remote control Plane sites as they have the best weight to power ratio but the problem is finding one that will fit into your player as most seem to be slightly larger. You need to find one over about 200mAh to give you any reasonable play time any thing below that will only give you 2 or 3 hours.
You could try a mobile phone repair they may be able to test the battery and offer you solutions.
  #27 (permalink)
Old 28th Jul 2006, 10:33 pm
thanx tadad this is very upseting as it would not charge before and then i had some success and it charged.. and then now when i hook it to the pc through the usb while the pc is on, it is no longer charging like before
do i hook it up to the computer too much? could that have messed up the battery charging ability
ohhh this is the sucks :cry:
i wil leave it charging overnight again i am hoping it will charge
  #28 (permalink)
Old 28th Jul 2006, 11:05 pm
nevermind , friend
i have solved the problem
it appears that the usb cable supplied was faulty, or the usb port i was using was not good.
i got out a different usb cable and inserted it into a different port. the player has now charged up quickly
i suppose that some players come with poor quality usb cables? and that people who are having battery charge problems should check out their cables and usb ports first - before resorting to a battery change
  #29 (permalink)
Old 28th Jul 2006, 11:14 pm
Nikki, Lithium polymer batteries actually prefer frequent 2 to 4 hour charges rather than running the battery dry and doing a full charge as this puts stress on the battery and can shorten its life. Sorry to hear you are still having probs though from memory your player is only about 2 weeks old.
Try hammering the seller for a replacement because what you are experiencing is not normal for these players.
  #30 (permalink)
Old 31st Jul 2006, 6:53 pm
Default I can't recharge the battery of my player
I NEED HELP
i cant recharge the battery of my player when i tried to conect to the recharger the charger have the green light but my player said that it have just a half of the battery power
i tried conecting it to the pc y could see and write the data in the player but i coulden't recharge it
then i try to discharge the battery completely and when i did for a few seconds the recharger showed the red light before that it showed the gren light again but the said that have no power in the battery
i tried with an old firmware but hapen the same thing green light but no power
now my player have no poer and i can't rechage it
the battery have this numbres: -WMDC PL402040 +270mAH 0602051
someone can tell me wath thats numbers means
PLEASE SOMEBOBY HELPME i don't know what to do :cry: :cry: :cry: :cry:
sorry for me english im panamenian
Unibit X-320 Player - How do I charge battery? TyphoonTycoon Support and How To 1 24th Nov 2007 8:50 pm
best way to charge battery Aiu Support and How To 3 11th Jan 2007 6:20 pm
18 Hours Continuous Music Play on a Single Battery Charge. tadad1 General Discussion 0 17th Nov 2006 7:40 pm
how do i charge the battery peruvianfreak250 Support and How To 1 18th Sep 2006 5:59 pm
