Battery Charge Problem?
Old 18th Jul 2006, 9:46 pm
Guest
Posts: n/a
Default Battery Charge Problem?
hey i just got my pink ipod nano clone mp4 player off of ebay
i used it and the thing is amazing and love it so much except its battery finally ran out so i plug it into the computer to recharge and wait for hours and take it out and the battery is still low and will only play for 6 minutes
ive tried the wall charger and different usb cables
is it possible my battery is messed up and i need a new one? will i hav to return my mp4 player. i have been waiting for weeks for this thing and now im having problems this really sux.
please any advice would be greatly appreciate
Old 18th Jul 2006, 10:10 pm
Guest, If you have tried the charger and another USB cord the only other thing I can think of is the player must be turned on for it to charge, otherwise it is a faulty player and you should contact the seller for repair or refund.
Old 18th Jul 2006, 10:18 pm
Guest
Posts: n/a
Default Re: Battery Charge Problem?
last thing i will try is leave it having a long song playing while it charges
if it still doesnt work i guess i will have to return it :cry: such a shame, i love this thing.
Old 18th Jul 2006, 10:31 pm
Guest
Posts: n/a
So far, success seems to be happening :lol:
I have been sitting here listening to a very long dj set i uploaded to the mp3 player while the usb cable is plugged in. i unplugged it for a second and the battery bar is 1/4 full. i also took it apart earlier and smushed the battery in tighter
hopefully it shall charge the whole way i will let you know
Old 18th Jul 2006, 10:34 pm
Guest, When you plug the player in it should show a connection screen and there should be a little battery indicator that displays an animation while the battery is charging. If the screen goes into sleep mode and turns off that is ok and it should come out of sleep mode when you push a button and still be charging.
Old 18th Jul 2006, 10:41 pm
Guest
Posts: n/a
yes it did have that screen and the sleep mode and it was still not charging at all before.
it seem to only be working when i leave songs playing on it now while it charge.
i am hoping it will charge to more than a 1/4 on the indicator
-nikki
Old 18th Jul 2006, 11:10 pm
Guest
Posts: n/a
it is another success to be noted
i unplugged usb again to see that it has blinked at half-way mark on the indication but has not stayed at half yet
but it seem to becoming more charged
i will leave usb plugged in and song running overnight to hopefully have it attain a charge of full
i will inform you
-nikki
Old 18th Jul 2006, 11:12 pm
nikki, will keep my fingers crossed.
Old 19th Jul 2006, 12:15 am
Guest
Posts: n/a
excellence!!! thank you tadad for recommending to leave it on and have the songs play when i recharge i think the method is working as the indicator is now 3/4 full
i am very happy that the mp4 player does not need a return :lol: hopefully this is luck that will continue.
- nikki
Old 19th Jul 2006, 1:08 am
Guest
Posts: n/a
VERY VERY HAPPY it achieves full charge now i test tomorrow to see battery life length i am pleased the progress is made thank you tadad i am of much relief right now
Unibit X-320 Player - How do I charge battery? TyphoonTycoon Support and How To 1 24th Nov 2007 8:50 pm
best way to charge battery Aiu Support and How To 3 11th Jan 2007 6:20 pm
18 Hours Continuous Music Play on a Single Battery Charge. tadad1 General Discussion 0 17th Nov 2006 7:40 pm
how do i charge the battery peruvianfreak250 Support and How To 1 18th Sep 2006 5:59 pm
