3.5" PMP Question
Old 24th Jul 2006, 12:09 pm
Terrah89
Guest
Posts: n/a
Default 3.5" PMP Question
hey, i got this zarva 3.5" portable media player which seems to play most videos without conversion but can u get liek homebrew games or themes for it?
Old 24th Jul 2006, 3:00 pm
Hey Terrah89, more details of your player along with pictures would be good. As far as I know I can tell you that adding more games should not be attempted, you can kill your player. Also, I would say that most people dont have a 3.5" player on this forum most of us have ipod nano clones with 1.5" or 1.8" screens so the possibility of finding one in hebrew gets even harder. I dont know who will be able to help you with that.
[size=12]Enkay Blog - Comprehensive Blog that talks about Technology, Web Reviews, Car Reviews, Interesting Financials & Videos from across the web!
Old 25th Jul 2006, 2:48 am
Default Re: 3.5" PMP Question
Terrah89
PMP's have a totally different board to what the MPx, MP3/MP4 players have. If you software doesn't need conversion, then I'm about 99.9% sure it doesn't use the same board as the MPx players on this site.
I have some PMP's as well and it's very hard, almost impossible to find any tools to modify them with. I've even asked the manufacturer and he is unable to get this from me as they buy the chip/boards from the manufacturers who don't release this information. This is to protect their product and if they only have the tools, then the only ones that can change it is them which will charge for. Economics I guess.
I do find some, I will surely post it on this site for you and everyone else.
Old 25th Jul 2006, 5:35 am
Terrah89
Guest
Posts: n/a
its 20gb 3.5" tft thats bout all the specs im sure of. got it for 350$au in a chinese computer fair in shanghai. I think some1 on a different site found a way of skinning his iRiver pmp o and this pmp has a game on it so i thought there mite be hope of getting other stuff, cant really check the site tho cuz its all in chinese
Need "private key" and "devcert template" adminn Support and How To 1 31st May 2010 5:07 am
32gb 2.8" touchMP4 question ballsofsteel Support and How To 0 22nd Oct 2009 7:16 am
"Blown-z" now trading as "excesories" tadad1 Bad sellers/Blacklist 2 15th Feb 2007 5:09 pm
[solved] USB 2.0 "Full" and "Hi" speed i Zepheris Miscellaneous 4 12th May 2006 11:18 am
