Silicon case
I would just like to mention that i was in one of my local shops here i live
and bought a knew boxed silicon case for my nano pod (clone). They also had a selection of diff ones for Ipod and the shuffel and in black or white All for £1 each. is this a good deal? |
Hey Applemac, well doesnt seem like a bad deal, however are the cases made to fit the nano clones? or do you have to modify them.. to me it seems that if you can just buy it from a local store that it wont fit exactly too well. Let me know, and if it fits fine..then great deal!
Well yes there was some mods done to it but it will do for now.I had to make a hole in the side for the jack plug and make the window a little larger.
yeah, do the buttons all fit into the little circle created in the case?
Can't go wrong for £1 each can you?
Sounds like a great deal if you compare it with the proper iPod skins! Phew, they're expensive! |
| All times are GMT -7. The time now is 10:50 pm. |
