Competition: Redesign the "ranks" images
Old 28th Jul 2006, 6:56 am
Default Re: Competition: Redesign the "ranks" images
Well i tried a few combinations for the favicon and some worked and some didnt - I tried the nano clones in both black and white however since the image size for a favicon is restricted to 16x16 the image appeared so small that it all just blended in. After trying a few different players I finally came across one that looked okay. I have uploaded a zip folder which includes: a larger favicon which also can be used which is 32x32 which is a lot better looking, an animated favicon in gif and png format and a readme file that indicates how to install both the regular favicon as well as the animated one.
Download Here:
http://rapidshare.de/files/27329941/...layer.zip.html (10kb)
http://www.megaupload.com/?d=CPIW0XM7 (mirror link - 10kb)
[size=12]Enkay Blog - Comprehensive Blog that talks about Technology, Web Reviews, Car Reviews, Interesting Financials & Videos from across the web!
Old 2nd Aug 2006, 1:51 pm
Well heres another one, a modification of the equalizer one that I had - this one is better when compared to that one so here goes. I think im the only one participating - maybe ive already won ..hehe..anyway check it out.
Standard Ranks:
Special Ranks:
Old 3rd Aug 2006, 8:09 pm
bsaylors,
Wow, those are great!!
Keep up the good work mate!
Look forward to everyone else's submissions.
We will give you full credit for your work if you win and we use it on the site so come on, submit your work and get famous!
Old 3rd Aug 2006, 8:21 pm
Thanks admin, Yeah I was thinking other people would submit considering there is a pretty sweet "prize" too
Old 3rd Aug 2006, 8:29 pm
i want to enter:
  #16 (permalink)
Old 3rd Aug 2006, 8:33 pm
Nice Job man.. I like the idea of rings! rings of saturn around the mp4
  #17 (permalink)
Old 3rd Aug 2006, 8:58 pm
PhantomX,
Looks great!
I like the "error" for Spammer - that's a nice touch.
  #18 (permalink)
Old 4th Aug 2006, 11:56 am
Hello,
here is my part... I want to say I have not simply copied a picture, I have completely edited it myself. I have put a photo in the display and made the "pixel effect" on the display. The "Spammer" has a recycle bin in the display, buts that's not really seeable. Here's a picture of the original size:
Here are the results:
I have choosen this layout because I think it's the best to show your status and which status you can get.
The gifs have transparency and are ready for the forum (I tested the max. size without changing the site borders and it was 156px). If a bigger version is needed, there is no problem, I have the Source files. :]
greets
edit 8.8.06: Images updated and improved background transparency.
  #19 (permalink)
Old 4th Aug 2006, 1:25 pm
I've got a tiny question... the images have to be the same size as the active ones or can have new sizes?
Because the ones posted here are all very beautiful, but I think they are not very suitable to have as a rank image... they make every post look very long and take a lot of screen (talking in a vertical way)..so I'd propose a fixed width & height to define as a standard...
What do you think about that idea?
I will make my images after knowing what the admin thinks...
I'd like to have to scroll less :P
  #20 (permalink)
Old 4th Aug 2006, 3:46 pm
Mine will fit. I tested it before. :P
greets
Need "private key" and "devcert template" adminn Support and How To 1 31st May 2010 5:07 am
Can't "unlock" 16GB 2.8" Touch Screen MP4 player javitony Dead Players 5 16th Dec 2009 8:15 pm
"Blown-z" now trading as "excesories" tadad1 Bad sellers/Blacklist 2 15th Feb 2007 5:09 pm
[solved] USB 2.0 "Full" and "Hi" speed i Zepheris Miscellaneous 4 12th May 2006 11:18 am
