Earphone question
Old 26th Jul 2006, 11:03 am
the_game969
Guest
Posts: n/a
Default Earphone question
I have a nano clone mp4 player and my earphone just broke yesterday,I was wondering wich is the good size of earphone to fit my nano clone mp4 player earplug? Someone told me that the 3,5 mm will fit in but another one told me it's the 2,5 mm! I think that the one who's telling me 3,5 mm is right but since I know this forum and since you guys know alot about those types of player I was thinking if the size of the mp4 player earplug is really 3.5 or 2.5!
Thanks,you guys are doing a great job!
Old 26th Jul 2006, 11:21 am
Hey the_game969 the right size is 2.5mm and there are a few sellers selling them and as tadad1 has said earlier in other posts that you can sometimes find them at the local walmart. Hope that helps!
[size=12]Enkay Blog - Comprehensive Blog that talks about Technology, Web Reviews, Car Reviews, Interesting Financials & Videos from across the web!
Old 26th Jul 2006, 11:29 am
Guest
Posts: n/a
Default Re: Earphone question
This depends upon which player you got. My first one had a 2.5mm cell phone connection (not good, IMO) and my second one had a standard 3.5mm headphone connection.
Old 26th Jul 2006, 11:48 am
Hey "the_game969" mostly all nano clones have 2.5mm jacks, if you can email me a picture of your player at nktech (at) gmail (dot) com then I will be able to tell you or if you can post the image here then I will be able to better help you. Hope that helps!
Old 26th Jul 2006, 2:37 pm
the_game969
Guest
Posts: n/a
Well...I don't have a cam to send some pics but I can give you the link of the place where I bought it on ebay,hope that helps!
http://cgi.ebay.ca/ws/eBayISAPI.dll?...tem=9730910355
If it's really the 2,5 mm then I would like to know if we can get good earphones because the one I had was not that great.
Thanks for the help guys!
Old 26th Jul 2006, 2:52 pm
Hey "the_game969" I have one similar to that unit and im pretty confident that it is a 2.5mm headphone. You can get good headphones in Walmart (as Tadad1 has suggested in other posts) or you can try looking online on ebay - although I do suggest getting some from Walmart because just in case they do not work right or dont fit that you can return them and get another pair.
Old 26th Jul 2006, 7:19 pm
Guest
Posts: n/a
Then I'm going to Wal-Mart tomorrow...thanks for the help!
earphone jacks Camaro General Discussion - Uxcell.com 3 20th Feb 2007 8:53 pm
Is it possible to listen radio without the earphone? Lejigabou Support and How To 3 11th Nov 2006 4:41 pm
Earphone Adaptors 2.5mm to 3.5mm jay Miscellaneous 6 19th Sep 2006 7:39 pm
Earphone question Donkez Miscellaneous 11 8th Aug 2006 11:45 am
earphone problem the_game Support and How To 1 19th Jun 2006 4:25 pm
