head phone plug size
Old 29th Jul 2006, 4:20 pm
Default head phone plug size
I have a 4GB black nano clone. The head phone jack is on the side and is smaller than a standard head phone plug (3.5mm). It came with headphones with the small pug but I would like to upgrade them. Can I get an adapter to the smaller size with a 90 deg angle ?
Old 29th Jul 2006, 4:46 pm
Default Re: head phone plug size
mike_e, You can indeed get a 2.5 - 3-5 stereo adapter, I am using one that is for a Nokia 5510, 6600, 3650, or 3660 mobile phone.
Old 29th Jul 2006, 9:49 pm
that is exactly what i've been looking for. did you get that one from any particular store or with the fone?
Old 29th Jul 2006, 10:12 pm
breech, there are a couple of different types, I got mine off TradeMe.
HERE and HERE
Old 30th Jul 2006, 2:28 pm
Guest
Posts: n/a
Thanx for the info. I will have to order a couple.
Old 31st Jul 2006, 8:47 pm
http://cgi.ebay.com/2-5mm-to-3-5mm-S...QQcmdZViewItem If you haven't already ordered, heres the one I got, works great, no cord and is only 4 dollars with shipping
Old 31st Jul 2006, 9:33 pm
Default Re: 2.5mm to 3.5mm White connector with gold tips
Hi,
In the same vane I have just purchased 5 of the following from ebay... with gold plated tips and female socket... in White.
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN%3AIT&rd=1
and for only 99p's each.
ear plug kelly07 Support and How To 5 28th Feb 2007 12:11 am
how do I get a new plug for my mp4 player mymp4 Support and How To 5 12th Dec 2006 8:33 pm
Land formation that looks like head with a iPod Cool razzer001 Miscellaneous 1 7th Dec 2006 4:13 pm
usb mic into one end and plug the other side into my mp4 Lorne Support and How To 10 6th Nov 2006 5:44 am
How to: Plug in your player admin Knowledge Base and FAQ 0 12th Sep 2006 3:17 am
